Old 08-08-2019, 07:46 AM
Andre's Avatar
Andre Andre is offline
Default 64 65 GTO lemans auto shifter parts
I'm looking for the plate and hinge linkage that bolt to the bottom of the floor of 64-5 GTO/Lemans with floor mounted shifter. If you have a parts car, maybe it is still on there. I searched Tripower Nationals for 2 days with no luck. Please email me at arayman.com
Old 08-08-2019, 08:44 AM
Well apparently you did not look hard enough. I had the whole setup from shifter to tranny laying on the tarp in plain sight. Sold it late Saturday. Sorry
Old 08-08-2019, 10:30 AM
chrisp chrisp is offline
Have a few complete but not breaking them up $250 plus the ride.
Old 08-08-2019, 10:49 AM
Murf Murf is offline
Sent a PM. Email addy is invalid.
Murf
Sent from my iPhone using Tapatalk Pro
Old 08-08-2019, 11:17 AM
That is what I got for mine.
Old 08-09-2019, 07:37 AM
Andre's Avatar
I saw the complete set ups at Norwalk, and I don't need a complete set up, nor would I ask someone to break up a set.
Old 08-09-2019, 09:50 AM
Yeah you more than likely wouldn't get anyone to break up an assembly but I took it that is what you needed when you mentioned "linkage". As tough as this item is to find, if you find an assembly buy it, use what you need and sell off the rest. I'm sure the market is strong even for just the rods.
Old 08-09-2019, 11:36 AM
I’ve got one if you still need it.
Sorry your PM didn’t show until I closed & reopened Taptalk.
Old 08-09-2019, 02:50 PM
Rocco Testa's Avatar
Rocco Testa Rocco Testa is offline
If your not looking for original, shifter works sell a copy of the shifter but it uses a cable which is much better to install.
Old 08-09-2019, 02:56 PM
Interesting
Old 08-12-2019, 07:48 AM
Andre's Avatar
I used the shiftworks kit on my 64 with the TH350., and also swapped the lens over to indicate 3 speeds. It works well. This car is remaining as a 2 speed, and if I couldn't find these pieces, I would probably switch it also, but I was fortunate to find what I need.
Old 08-12-2019, 05:02 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default I need the link arm
Looking for the “link arm” that ties these two components together.
Anyone have the 64-65 vertical short arm?
Thanks, Chris
ID:	517550   Click image for larger version
ID:	517551   Click image for larger version
Old 08-15-2019, 07:41 AM
Andre's Avatar
Chris- I might have a spare link arm. I'll check
Old 03-24-2020, 04:40 PM
60sstuff's Avatar
Default ROD, Gearshift Control
Andre,
It’s been awhile, but we’re you able to find one of these.
Still need #15 in the illustration. Rod / link arm.
Thanks, Chris.
ID:	535245   Click image for larger version
Old 03-25-2020, 07:44 AM
Andre's Avatar
I put this to sleep sometime ago. I actually had a spare arm, but someone needed it, so it is gone. Maybe I have another one. I'll check
Old 03-25-2020, 11:18 AM
Scott Thelander's Avatar
Default ...
https://seattle.craigslist.org/sno/p...089757309.html
not mine
Old 03-25-2020, 12:49 PM
60sstuff's Avatar
Originally Posted by Scott Thelander View Post
Thanks Scott.
I just need the single rod.
I’ll keep looking.
Chris.
