Old 08-30-2019, 11:52 AM
NYGTO's Avatar
NYGTO NYGTO is offline
Default Surface Rust Lacquer
Hi guys, I'm looking for advice on removing surface rust from lacquer paint from a trunk lid.
What is the gentlest method of removing the rust and bringing the existing paint some life? Thanks for sharing your ideas and experiences.
Old 08-31-2019, 03:43 AM
1965gp 1965gp is offline
I have heard of people washing the part with CLR (bathroom cleaner stuff) and the results looked good.
Depending on the severity- you may be able to use a polish.
I have been using dish soap and a very fine scotch brite pad - like the kind you get at the grocery store. Start with the blue ones then go to yellow/green if you need it. Be careful as it will certainly take paint off.
After the scotch brite I buffit with a light compound, then polish and finally wax.
Here are some pics of my 60 wagon before and after. Let me know if you want to know what products I used.
Old 08-31-2019, 08:34 PM
NYGTO's Avatar
Thanks, what you did makes sense because the dishwashing liquid will be gentle on the remaining paint. The CLR scares me a little bit. Everytime I see that beautiful Safari wagon I get a big smile. What a nice ride! Thanks for your help.
Old 09-14-2019, 01:30 PM
65blackplate's Avatar
65blackplate 65blackplate is offline
If you don't want to do the CLR.
The Works bowl cleaner with a white scrub pad dissolves it without touching the paint. I have used it on my white original paint GTO
________________________________________
65 GTO
owner since 84
original ca car
