Old 09-03-2019, 12:18 PM
T/A addict T/A addict is offline
Default oil filter clearance
I picked up a used set of headers for my 400 in a 69 and after installing them I no longer have clearance for my oil filter (which I had removed before installing) the oil filter is WIX - 51258.
Is this because these headers are not for the 69 Firebird or is there a shorter oil filter I need to use?
Old 09-03-2019, 01:59 PM
grandam1979 grandam1979 is offline
Would the angled filter adapter help to tilt the filter back? I run a Bosch 3423 with long branch manifolds that might help you also.
Old 09-03-2019, 02:38 PM
455'73inElCamino 455'73inElCamino is offline
I have several extra mounts that I bought because I was having trouble making mine "fit". I will see what I have and let you know.
440, E-heads, Performer RPM, holley sniper, "stump puller" cam, 3.42 gears, 3540 lbs
Old 09-04-2019, 07:41 AM
Sport69 Sport69 is offline
You probably need the angled filter mount.
Cholesterol Bad Adrenaline Good
Do it till your eyes bug out!
Old 09-04-2019, 07:58 AM
Never knew there was an angled mount..... Sounds like what I need then. Should be a simple enough fix.
