SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 09-16-2019, 08:13 PM
pontiac rodder's Avatar
pontiac rodder pontiac rodder is offline
Default 498 engine
Pontiac 498 for sale carbs to pan and Crank trigger to convertor. It is offered on PY first before I try else where. This is a very strong and well built motor with high end components. The car has not been used for the last 4 years with less than 20 passes on it. I'm just going in a different direction with the car it was in.
On 9/5/19 it went 9.59 @ 139 in a 3500 lb. car on a nine inch tire.
Cast IAll block 4.250 stroke 4.320 bore (498)
Kauffman 400 cfm high ports (13.6 compression)
Wenzler tunnel ram
2-800 Edelbrock carbs
794 hp on dyno
Cast IAll block
Ohio 4" crank
Oliver billet steel 6.800 rods
Ross pistons
Comp Cam 288/292@50 750 lift
Smith bros 3/8sx145 push rods 5/32 ball each end
Crower 8.47 offset lifters
T&D 1.65 offset rockers
Kauffman 400 cfm high ports 64cc w/Manley stainless steel valves (no port work done to heads)
Wenzlers tunnel ram with 2 800 Edelbrock carbs (tunnel ram was port matched to heads)
Meziere water pump
MSD crank trigger ignition
ATI balancer
Melling 80 oil pump
Jegs mini starter
TCI flex plate
Coan 5000 stall convertor made for this combo
If you are serious and have questions I prefer PMs
15K
I will not ship or separate
Thanx
Peter D.
Old 09-19-2019, 07:50 PM
SOLD! Thanks PY
