1963 LeMans For Sale - Chicagoland Area
***Being Sold As Is – Roller Only – No Motor or Transmission***
No Trades $13,500 Firm 1963 LeMans Sports Coupe Body Plate Reads as Follows: Style 63-2217 Trim 217 2C-4B-4G-4R 3250 lbs w/ Driver (Weighed at Norwalk) All Steel Except for Hood Scoop Yorktown Blue Poly Original Paint (From What I Gather) Chromoly 8pt Cage w/Halo – Tig Welded and Professionally Built/Installed Strange Engineering Dana S60 Rear Housing w/ 4.56 Pro Race Gears & Spool Strange Engineering 35 Spline Axles w/ 5/8” Wheel Studs Competition Engineering Ladder Bar Suspension QA1 Coil over Shocks Wilwood Disc Brakes Front & Rear Wilwood Master Cylinder Mark Williams 3.5” Chromoly Driveshaft 44 7/16” length 10,000 RPM Max Critical Speed Hurst Line-Loc Lokar Adjustable Gas Pedal – Original Mechanical Linkage Included Weld Racing Pro-Star 96 Series Wheels 15x4 Front Weld Racing Pro-Star 96 Series Wheels 15x10 Rear 3.5”BS Mickey Thompson ET Front 26x4.5x15 Tires Mickey Thompson ET Street Bias Ply 28x11.5 Tires (No Tubes Installed) BOP Engineering Front Motor Plate Customized For Vehicle Engine Cradle Crossmember Modified for Additional Clearance to Run Engine Diaper w/Tow Hook Attachment Steering Rod Has Been Modified to Remove for Extra Header Installation Clearance RCI 10gal Fuel Cell Modified for 1/2NPT Outlet Fittings Fuel Cell Custom Mount Included All Moldings Included Extra Windshield Moldings and Window Side Moldings and Rear Window Trim (Lower) Included Set Up for Clutch Assisted Transmission (Modified Trans Tunnel) Custom Clutch Heavy Duty Z-Bar and Clutch Actuating Rod Lightweight Modified Trans Crossmember Hooker 2” Headers Modified for Vehicle 3.5” Exhaust Included (Exhaust Exits Just Behind Driver & Passenger Seating Locations) Hood Has VFN Extra Large Super Duty Scoop New Windshield and Weatherstrip/Seal Professionally Installed Original Seats Included Extra Set of Racing Seats (Plastic/Polymer) Included I Do Not Have PHS Documentation VIN 263P100915 Can Help Deliver to Chicagoland Area Up To 100 Miles On a Weekend Day Located in Wauconda IL – Zip Code 60084 PM Me If Interested and Include Your Phone Number and Name and I Will Contact You Last edited by Apache Warrior; 10-01-2019 at 01:04 PM. |
Does it have a title? Do you have the grills?
Title - Yes
Grills - Yes, they are currently installed. No fuel system currently in the car other than the fuel cell. Last edited by Apache Warrior; 10-01-2019 at 09:56 PM. |
Has the Chassis ever been certified?
How fast has the car run? Could you post some more pic, interior and engine comp? Thanks
PM Sent
Have been traveling so slow to reply, my apologies. I will be home this weekend and will try to take new pictures of the engine bay, underside, trunk area, interior.
Chassis is not certified. I actually made a typo as this is truly a 6pt chromoly cage with a halo added. No dash bar. Radiator is not included. Roller means no motor or transmission. Car went 11.70's at Norwalk with a mild 474 and Jerico. These were first and only runs with a solid cam and 300cfm Edelbrock heads and single 4BBL. |
Thanks, looking forward to seeing more pics.
Is this for still for sale PM sent
I never heard back from him. I don't think he is on here much.
Bump.
More pics to come. |
Sale pending.
Congrats to KK for getting it back
1963 Tempest 1969 Pro Touring GTO All Aluminum 505 IA, 4L80, Roadster Shop Chassis 2004 GRAND AM TUBE CHASSIS RACE CAR 505 IA II 7.92@173 |
