Old 10-01-2019, 07:06 PM
grd777 grd777 is offline
Default Is this a correct waterpump for my 72 formula
Looking to buy a waterpump casting number 482138 I have a 400 engine
Old 10-01-2019, 07:21 PM
Judge273's Avatar
Judge273 Judge273 is offline
My 72 Formula has that cast number on the water pump too.
Mike/Illinois
Old 10-01-2019, 07:38 PM
77 Canamman's Avatar
https://www.ebay.com/itm/1972-1971-P...oAAOSweEFbLB3u
https://www.ebay.com/itm/Pontiac-Wat...UAAOSwFANc22lj
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 10-01-2019, 07:49 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
depends on the build date, here is a good post from the past with a very knowledgable source in Ol Pinion Head(Roger) :
http://forums.maxperformanceinc.com/...d.php?t=830803
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 10-01-2019, 08:00 PM
What I have on my car now is casting number 4821138. But the date is odd c038
Old 10-01-2019, 08:04 PM
Feel free post a pic of the date. I stand by earlier posts, have pulled too many "138"s over the years.
Old 10-02-2019, 01:07 PM
unruhjonny's Avatar
isn't that the casting number used from 1971 through to the end of Pontiac V8 production?
1970 Formula 400
Old 10-02-2019, 07:09 PM
the first "296" casting pumps did not show up till mid winter 1972. The first couple years of "296" casting pumps had a small 72 cast into them. Common to see that style of casting with the small 72 on original '73 & '74 dated "296" pumps.
More from the above link:
"488296 continued on throughout the '70's... basically it is the most common "tall" w/p casting. The font & style of casting numbers got much bigger as the '70's rolled along. Even original Pontiac 301 & 265 waterpumps were built from this casting, be it with a different design low drag cast impeller. Often the impellers have been changed at rebuilders, so don't count today, on a very late dated one to have it's original low drag cast impeller."
Should have also noted earlier that sometime in '79, Pontiac Central Foundary went away from using Alpha Numeric date coding on the "296" water pumps & went to a Julian date code, this was for '80 & 81 model 301's & 265's as well as over the counter Service Parts water pumps.
Old 10-02-2019, 07:34 PM
MescaBug's Avatar
MescaBug MescaBug is offline
Tall 488296 casting numbers and the small 72 cast on a K191 pump (November 19, 1971). That's from an original 72 cars with a November 26 production date.
I need to look at my 72 GTO (Oct 26th) and see what pump I have on that car
I always thought the 488296 pump with the 72 casting are the correct one for 72 cars.
