Old 10-04-2019, 12:29 PM
slowride66's Avatar
slowride66 slowride66 is offline
Default 68 GTO 10 Bolt rear axle run out" Right Stuff Detailing 4 wheel power disc upgrade
Howdy Y'all I am working on my buddies 68 GTO hard top doing a "Right Stuff Detailing "4 wheel non power to 4 wheel disc brake upgrade.
What A PITA. so today's problem is when the car goes left it makes a scuffing noise out of Left Rear that goes away when brakes are applied .
I have been looking to find the axle run out for this type of 10 bolt NO "C" clip the 4 bolt flange mount.
I am really chasing my tail at the moment & asking for some help .
Thank you all very much.
SR66
SLOWRIDE "take it easy"
https://www.robharleydetailer.com/
I'm not prejudice, I hate everyone Equally.
The best proof that there is intelligent life in outer space is;that they haven't made contact
Old 10-10-2019, 07:25 AM
ts3189's Avatar
ts3189 ts3189 is offline
can't tell you the runout #, but had same noise you are describing replaced axle bearing problem solved. national bearing # rw-507-cr.
Old 10-10-2019, 09:59 PM
slowride66's Avatar
thanks I will give a look see.
SE66
