Old 10-10-2019, 07:40 PM
jonathonar89 jonathonar89 is offline
Default 1977 W72 option Pontiac 400 with matching auto trans
Factory 1977 W72 option 400 with TH350 transmission. Came out of a Trans Am. I never tested it as I purchased it from someone who didn't know how to install it in his Nova.
Correct factory chrome valve covers
Correct 17057266 carburetor
Correct early style W72 intake manifold
Correct early 557 casting (78-79 W72 had the 988 casting)
Correct 6X-4 heads
Correct Y6 block code
$1500
Located in Island Lake, IL
Untitled by Jonathon Randolph, on Flickr
Old 01-01-2020, 01:48 PM
Interest has died off on the engine so I’ve been wondering what I should do with it lately.
Keep waiting for a buyer?
Ditch the transmission and throw the 400 in my ‘79? (set aside the original engine)
Sell the engine in pieces? (Part our the engine)
What would you do with this engine? I’ve had online offers and interest messages but not one person has showed up to make a legitimate offer.
Old 01-01-2020, 02:24 PM
77 Canamman's Avatar
It's a 557 block, so no interest in a high performance build, although these will take 450HP all day long properly prepped. Other than for restoration, nobody want these.
The 6X-4 heads are desirable for cheap CR bumps in 455's
The carb is a great one with a jet and orifice change.
The valve covers are desirable if not pitted and dinged.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 01-01-2020, 05:36 PM
leon leon is offline
I might be interested. Just picked up a 69 convertible I am thinking about just buying an engine vs building one.
Old 01-03-2020, 01:17 AM
This what I figured. Thought someone would want it considering the heads and carb....or restoration. I will have to figure out something. Maybe setting aside the original engine will have to happen.
Old 01-03-2020, 10:00 AM
abefromen's Avatar
abefromen abefromen is offline
I'll give you $20 for this plastic connector in the vacuum line from the back of the carb to the vacuum advance. I see in your one pic it's still there. It's a spark retard delay orifice I need. You can carefully sandwich it between two pieces of cardboard in an envelope and mail it.
ID:	528066   Click image for larger version
Old 01-23-2020, 12:59 AM
Still available!
Old 01-26-2020, 07:42 AM
se428bandit's Avatar
se428bandit se428bandit is offline
Do you know the code on the trans? Is it the # match to the engine. I might be interested in that.
Old 02-02-2020, 08:18 PM
Default Sold
Sold
