Thermostat
I’m finding that the only thermostat that doesn’t have a raised outer edge that interferes with the housing is AC Delco. Is there an alternative? Can’t seem to walk into an auto parts store that stocks one. Getting ready to grind the edge off lol.
Thank you! |
Stant Mr. Gasket. All of them if your thermostat isn’t fitting you are doing something wrong. The gasket goes under the thermostat.
Under? Never heard of that before. Thermostat sits in the indentation of the intake with gasket on top, tgen the housing.
I was just thinking out loud thought it might be your problem
Oh ok.
How bout this one?
https://partcat.com/stant Could it also be that the recession in that offy intake is more shallow than most? 45358 part # Thought pic would show up in link. It doesn`t. Gotta go down the menu. |
I have used those in the past with a few drilled air bleed holes in the flat metal mounting lip. Stant SuperStat Thermostats 45358
Bought some stats from a PY member and going to try them this coming spring. Tom V.
Thank you guys. I had the Stant already and ended up with the AC Delco, seemed to sit in the recess a bit better when tried them side by side. I’m sure either would work, tried one of those Motorads from Advanced, didn’t like It.
MotoRad 7200-180 Fail-Safe Thermostat https://www.amazon.com/dp/B000C5CE0W..._r4gRDb78CYCVP |
