73-77 A-body TECH Includes 73GTO, LeMans, Grand Am, Can Am
Old 10-25-2019, 04:18 PM
sport coupe sport coupe is offline
Default Grand Am Grand Prix tachometer
Will this tachometer fit all 73 to 75 Grand Am and any 73 to 77 with that style cluster?
ID:	522933   Click image for larger version
Old 10-25-2019, 07:56 PM
Bolt in, yes. function that would be the question. Keep in mind there were two different tachs for '71, 72's, & '73 model Pontiacs. One for points, one for unitized. Eventually, points distribs were no longer offered & every engine received an HEI distributer. Is there an ink stamped date & part number on the rear of the tach? have several such tach clusters mainly for electronic ign use, can pull them out in the AM, & compare.
Old 10-26-2019, 08:53 AM
On back side of tach ink stamped numbers 565800. Does that help identity which year the tach was used? Has a few more letters or numbers but to faint to read.
Old 10-26-2019, 02:13 PM
77 Canamman's Avatar
5658007 was the only tachometer part number listed for 1973-74 AH and AG models in the GM parts book.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 10-28-2019, 04:25 PM
Are all the 73 and 74 tach’s able to work on either the points or Hei? Is that wiring harness pictured for a 73/74 model only?
Old 10-28-2019, 07:00 PM
I would say YES.
HEI was a mid year 1974 addition, and unitized was available all of 1973.
