Old 11-15-2019, 08:18 PM
Mark G Mark G is offline
Default Winter UpGrades lets hear them..
Well for me
Converter swap ditch the dot tires new set of Mickey T's
Oil change clean everything
Old 11-15-2019, 08:22 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Building a new bullet, a roller cammed 4-bolt 428 to replace the tired 463.
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 11-15-2019, 09:03 PM
footjoy's Avatar
footjoy footjoy is offline
New cam and new heads and tri power.
Old 11-15-2019, 09:10 PM
Mean Green's Avatar
Mean Green Mean Green is offline
Induction Solutions Fogger
Motor/Mid Plates
Smith Racecraft Rack and Pinion kit
TRZ A-arms
Aerospace Components Front Brakes
2 1/8 to 2 1/4 Headers
4 inch Mufflers
Rhodes Tubular Core Support
Aluminum Driveshaft
Rewire Car
www.lancablingsolutions.com
Old 11-15-2019, 09:59 PM
Motor/Mid Plates
TRZ A-arms
4 inch Mufflers
Aluminum Driveshaft
Rewire Car
I did all that but took longer than a winter..lol
Old 11-15-2019, 10:43 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Gonna try and do more racing now that it's not 100 degrees.
Old 11-15-2019, 10:50 PM
quick67bird's Avatar
quick67bird quick67bird is offline
Fix wiring issues in my car.
Reinstall back window.
Fix all other issues I have found lol.
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 11-15-2019, 11:26 PM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
Tiger heads and intake are sent to BES. 535 short block going back to Butler to freshen. I sold the APD 1050 Maxspeed and bought the 1250 version. Sent the Hughes converter back back to loosen 200 more ( 6700). Looking forward to seeing how much it picks up.
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
Old 11-16-2019, 12:43 AM
Dragncar Dragncar is offline
New engine, 461 with High Ports. Pump gas, should be around 700HP. The old 455 deserved a good retirement. Freshen it and put it in a 79 TA street car with smaller can and RA round port ex manifolds.
Old 11-16-2019, 02:56 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
With plans to get to the first 2020 LTA event on the 1.5 mile Loring ME track, just minor changes to the lakester-
> Halotron-1 agent replacing foam in driver's fire system
> Some body work around the hole I made for the blower
> Try to find someone to mold a "smooth" Lexan body piece over the blower
> Add a solenoid activated secondary fuel bypass, for consistent lean warm-up
> Source a blower pulley to allow driving the blower a little faster
> Perhaps outfit the '59 GMC as tow/push/support vehicle
> Most important- stitch my name in place of prior owner's name on the used -15 firesuit I bought
Old 11-16-2019, 03:07 AM
Little more on my new engine. Its a bottom filled 73 400 block, .035 over Ross Fts, splayed billet caps, billet Crower mid weights and Scat 4.25 forged crank. It will have the 100% SD lifter brace and the High Ports with 2.20 valves were done by SD Performance and go 359cfm. Norris SS 1.65rockers with stud girdle. Big custom pump gas cam, 11-1 CR. Crower roller lifters. Northwind intake to start. Have several other to try also.
Will start with a HP 850, then HP 1000 and will try a 1050 and see how that does.
Old 11-16-2019, 09:59 AM
Mike S's Avatar
Mike S Mike S is offline
I am cutting the steel roll bar out and installing a cm cage. Going to reinforce the stock suspension points. I will also be notching the frame while I have it apart. I will also need all new safety equipment. The plan is to get my license to go faster than 10.00.
My last race I had 240lbs of weight, a 1.700 restrictor plate and pulled 4 degrees of timing in high gear. Still ran 9.99/133. Had a best 60' of 1.342.
Old 11-16-2019, 10:12 AM
GTO's Avatar
GTO GTO is offline
Lunati Mech. Roller. Blow through kit. Freshened 455 short block. Put everything under a stock hood. Freshen the trany and put in my spare converter. New paint and Judge stripes. Black out rims and trim. … After Christmas some re-wiring to put in a heater and wipers.
Runner Up Q16 Norwalk 2013!
Old 11-16-2019, 10:24 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Convertor(just put in) and an electric radiator fan so I can cool it down between runs.
Skip Fix
Old 11-16-2019, 10:43 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Does getting a car running for the first time in four years count as an upgrade?..... asking for a friend
Go fast, see Elvis!
Old 11-16-2019, 11:17 AM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
Last winter I got nothing done, shouldn't take much to beat that!
I do have heads and valvetrain now!!
Old 11-16-2019, 12:51 PM
ponjohn's Avatar
ponjohn ponjohn is offline
73 Ventura, back on all 4's after mini tub and 10 point bar.
Old 11-16-2019, 01:07 PM
pokey1 pokey1 is offline
This winter should be easier than the last three for me. Just putting on the tubular front a arms and coil overs. Then can change the stance and adjust for better weight transfer...
1967 GTO, 467 roller motor, e heads ported, tremec T56 magnum 6 speed and
9" done. EZ EFI 2.0 with FAST dual sync distributor and separate nitrous system done. Track is at 4300 ft elevation. so far a best of 11.95@116. Suspension now getting dialed in...tubular front a arms with dual adjustable coil overs HR Parts n stuff rear bar and whole car lowered 3 inches..
Old 11-16-2019, 05:07 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Been in mothballs for over 10 years. Same old 542 IA 1 and SC heads.
Ditched the glide and went turbo 400 and going to some m5 to drink. Did some black wheels and dumped the aero scoop to keep up with the times.
ID:	524602   Click image for larger version
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 11-16-2019, 05:17 PM
Jacking up the car 4 feet to match all the idiotic trucks around here...
Name:	Lemans frame off.jpg
