Old 11-19-2019, 10:52 PM
Cardo's Avatar
Cardo Cardo is offline
Default A/C Evaporator case to cowl seal
For those who have had their evaporator case out, what is used for a seal between the side opening where the air flows through to the cowl? A form of some sort i suspect....what did you use specifically?
"I know just enough to keep me here, but not enough to get me out"
Old 11-20-2019, 08:51 AM
pfilean's Avatar
pfilean pfilean is offline
Usually a foam seal. I ordered some closed cell foam from McMaster Carr and made my own.
Old 11-24-2019, 01:55 PM
aceaceca's Avatar
aceaceca aceaceca is offline
Mine was a glob of gooey rubber. No repro at the time I did mine. Jury rigged my own with closed cell weatherstripping.
Old 11-25-2019, 01:12 PM
Cardo's Avatar
Copy on the gooey rubber. Ordered some closed cell foam to work into the gap.
