Rear passenger window stopped working. When I use the window switch from the driver's' control the car's voltage drops but no window movement. How do I tear down the car to get to the rear window components?
With HT you have to remove rear seat first to access the side interior panels for removal
Carburetor building & modification services Servicing the Pontiac community over 25 years |
Did you check the local switch (right rear) as well? Are both not working?
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & a 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 2 Bonnie Cvt's & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
The car is a HT and the local switch is not working.
First thing I’d do is pop out the local switch and test it for power (key in run or acc). First see if power is coming to the switch and if yes then check for power leaving the switch when the switch is applied for up and down.
If the switch is getting power and working properly then pull the backseat, armrest and inner door panel to assess the mechanism. Since you say it’s drawing power it’s probably binding somewhere in the mechanism, maybe a broken roller or guide? Should be evident.
