THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
We have a new/never used Northern 20gallon parts washer (12 gallon solvent capacity). I'm looking for some recommendations for a good solvent to use. I believe it needs to be non-corrosive. Any help you may have would be greatly appreciated!
PB Blaster makes a good solvent. It is not mineral spirit based. Doesn't leave a residue and can be use on some plastics even. Sells for about $85 for five gallons at Napa.
30+ Years with NAPA. Happy to help with any auto parts questions. |
I just bought 5 gallons of parts washer solvent at Tractor Supply last week for around $58. I haven't used it yet, so I can't say how well it works.
69 Judge convertible........clone! Carousel red, parchment, hideaways, TH400, 10" Continental 3200 stall, 12 bolt with 3.42, 469 c.i. with ported #48's, ported cast iron intake, Cliff's Q-Jet and ported 2-1/2" Ram Air manifolds. |
I normally purchase mineral spirit based solvent from Rural King. It seems to last longer than mineral spirit replacements.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
My machinist uses Cascade dishwashing soap in his. No suds, cleans well. Simply soap and water.
Jeff |
Misread this thread.....I thought you had one of the heated steam spray wash cabinets, not a solvent tank. Please disregard!
Jeff |
140 Solvent is what we use. I don't like mineral spirits because of the smell... Thing you have to watch out for , if the unit has a plastic pump (cheapie) the solvent distorts the plastic and the pump stops working in short order.
Paint thinner.
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
Stoddard solvent add some auto trans fluid to soften the harshness.
I've used the Tractor Supply solvent. Works well, just make sure to keep the lid closed on the washer or it will evaporate.
"I know just enough to keep me here, but not enough to get me out" |
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
I'm going to try "purple stuff" in the same cleaner diluted 15-1 and see what happens. I can always add more if it's not strong enough. Probably won't try it for about a month or so as I won't need it till then. I'll let you know how it works out.
I bought one of those a few years ago... Got tired of fooling around with the water based degreasers and bought a solvent rated pump from Amazon .. modified it to fit and been using it that way since.
I use odorless mineral spirits but wondered if there was something better myself. Sent from my moto g(6) play using Tapatalk
Greg Reid Palmetto, Georgia |
Thanks everyone. Looking at the washer closer it does specify only water based. We had a decent (warmer) day here in PA yesterday so I ended up washing my M20 parts out in the driveway with good old gas. The parts washer will be nice to have in place though long term.
I used the stuff from Tractor Supply. It works pretty decently. Its reasonably priced compared to other stuff. When I was doing research it seemed like the cheap/safe stuff worked well if heated. Or you can use something with a much more dangerous flash point that works fine at room temp. Diesel seemed like a decent option if you didn't mind your garage smelling like a truck stop.
In retrospect I wish I had spent more money up front and bought a unit that heated the fluid. I didn't realize it before purchase.
1967 Firebird 462 580hp/590ftlbs 1962 Pontiac Catalina Safari Swapped in Turd of an Olds 455 Owner/Creator Catfish Motorsports https://www.youtube.com/@CatfishMotorsports Last edited by RocktimusPryme; 12-09-2019 at 04:06 PM. |
