Closed Thread
Old 12-12-2019, 01:18 PM
GOSFAST GOSFAST is offline
Default Pontiac Aftermarket Block?
Does anyojne have info on who is making the aftermarket (iron) blocks for these Pontiacs?
Not looking for vendors, looking for mfr?
Thanks, Gary in N.Y.
P.S. On a side note, would also appreciate any feedback on builders who have experience with these castings! Are there any drawbacks/pitfalls with respect to the necessary machining??
Old 12-12-2019, 02:33 PM
Gary H's Avatar
Gary H Gary H is offline
Two manufacturers, KRE, and All Pontiac
Old 12-12-2019, 02:49 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
They are the manufacturers but use an independent foundry to pour them.
Skip Fix
Old 12-12-2019, 08:43 PM
Half-Inch Stud's Avatar
Spotts Perf in Hatfield preps & assembles these blocks
Old 12-13-2019, 01:12 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Doesn't Kaufmann have part ownership in the foundry that pours the MR-1's?
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 12-13-2019, 01:37 PM
Steve C. Steve C. is online now
MR-1 block
In the beginning it was Tri-Cast foundry
https://www.tri-cast.com/
Post 338
https://forums.maxperformanceinc.com...i-Cast&page=17
Old information here:
Old 12-13-2019, 09:20 PM
Scott Roberts Scott Roberts is offline
Originally Posted by Steve C. View Post
MR-1 block
Post 338
Lol.... oh yeah... there's that.
Old 12-13-2019, 09:39 PM
Yep ! And technically speaking the MR-1 is actually a K&M Performance Parts block.
Old 12-13-2019, 09:58 PM
Right....
What was so funny about that whole deal was I was right and stomped their ass on the track up until I sold the car... 3 years...they blew up countless engines in that period...lol
Their argument in court was I tried to harm their business... not the facts about the block I claimed...
It all could have been easily averted...
Old 12-13-2019, 11:07 PM
And later they turned into butter !
https://forums.maxperformanceinc.com...4&d=1161530921
Old 12-14-2019, 12:49 AM
GTOGEORGE's Avatar
I love my butter block.......13 years and still going strong ! LOL!
GTO George
Old 12-14-2019, 01:44 AM
Stan Weiss's Avatar
Stan
Pontiac Pump Gas List
Old 12-14-2019, 09:37 AM
Lightbulb
Originally Posted by Scott Roberts View Post
Right....
Their argument in court was I tried to harm their business... not the facts about the block I claimed... It all could have been easily averted...
Sooooo, you were the whistleblower. Condolensces on buying a weak product. They got it better. Hope you were made whole again.
Old 12-14-2019, 09:44 AM
389 389 is offline
I don't see how they get away with calling them Pontiac, they weren't made by Pontiac....
Old 12-14-2019, 09:47 AM
Because they have all the Pontiac dimension... any stock internal or external part with bolt up...
They are copies of the OEM block but stronger
Old 12-14-2019, 10:28 AM
389 389 is offline
What I'm getting at is I'm surprised GM isn't giving them head aches..
Old 12-14-2019, 10:46 AM
Mike Davis's Avatar
They are not saying they are OEM GM blocks, They are calling them an aftermarket Pontiac block. Same as an intake manifold, oil pan, etc.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 12-14-2019, 11:38 AM
Hillard's Avatar
Hillard Hillard is offline
I have machined both and I have built both. I would have no issues using either one.
Old 12-14-2019, 11:55 AM
ID67goat's Avatar
ID67goat ID67goat is offline
How much machining needs to go into these blocks when buying one new? Just final hone or do they need mains align bored, decks squared, etc?
Old 12-14-2019, 01:27 PM
mgarblik mgarblik is offline
Concerning IA II blocks only. They come from All Pontiac with semi-finished cylinder bores. Pan rail, line bore/hone is done, deck is finished, oil filter pad, front and rear faces of block are finished. Every batch of blocks as they get newer, come in better and better. They are well within OE specs. for deck height/squareness, housing bore dimensions. If you want the block absolutely dead nuts perfect, you will need to have some machining performed just like ANY aftermarket block, or OE block. Current IA II blocks are as nice as any Merlin, Dart, World or any other quality aftermarket block. I can't comment on the MR 1, because I haven't built one. The shop I work out of has done 2 or 3, and no real issues to report. I have machined about 10 IA blocks. They are light years better than a 40+ year old OE block in strength and materials.
Closed Thread
