New distriutor
I'm in need for some info. Have a 67 GTO with points distributor. would like to install Electronic distributor, Just got a Parts place in dash tach. They say can use with pertronix ignitor ignition systems. Do I need to run new wire to replace resistor wire?
Yes, a continuous 12 volt source with ignition key on in run and start.
One simple solution is to install a relay triggered off your existing resistance wire. This way you or anybody down the road can easily go back to a points dist if they ever choose to. Side benefit is not having to track down or splice into a 12v keyed ignition source. You can get a waterproof 12v Bosch style relay with pigtail harness and mount for under $10 online.
The Following 2 Users Say Thank You to Entropy11 For This Useful Post: | ||
Just run a CD/MSD box with points, its just better. Nothing to fail and leave you stranded. If the MSD box does fail, switch a couple wires around and drive home.
X2 with the above even though it cost a tad more.
ditto
Run both wires through the harness just as the resistor wire was. Now you have the choice of a full 12 volts or the resistor wire. I still use the factory wire from the "R" terminal on the starter to have a full 12 volt while cranking, which your car, being points originally, should already be equipped with. |
Original points coil will still use the factory resistance wire. Lots of trash talk here at PY about Pertronix failure. Most all of it can be traced back to improper installation and/or improper wiring. Clay Last edited by "QUICK-SILVER"; 01-14-2020 at 01:25 PM. Reason: and/or |
I don't know, you're right about a lot of failures, but that many improper installs is harder to believe. I mean it's pretty straight forward, they'll tell you if they want 12 volts or not, and the reluctor wheel gap is pretty hard to screw up, but they've made that deal even easier now.
Probably the biggest mistake made is how someone goes about finding a reliable 12 volt source and whether they also have it while cranking or not. A lot of guys building these cars using new harnesses now have the option of coming ready to go for electronic ignition making things even easier. American Auto Wire is one place that offers the harness both ways. There is really nothing overly complicated about installing one. It's just that todays electronics are so hit and miss anymore. I've had them work fine in some cars and the exact same units not work so well in other cars. |
"No replacement for displacement!" GTOAA--https://www.gtoaa.org/ |
I have had 2 sets of points in my 455 since 1990. The last set was installed over a dozen years ago and I did it just because, but they were fine.
I have run that 62 iron distributor up to 8K on a Sun machine, never skipped a beat. There is a Mallory HyFire in the for sale section for 85$ shipped. That would do the trick. Been thinking about snagging it just because. But its there if someone wants to do the points CD box thing. |
Or, I bought a reman, HEI, for around 80$.
1970 amc rebel 4-door, faded blue paint,290 emblems on car, 455 under the hood.Turbo 400,3.15 gear. Best so far 1/8 et,8.90 on street tires, Since that I have added 400 heads. I call it a rat sleeper. |
And hope you get a Chinese product that works, or at least works for more than a couple years. I eluded to that issue in an earlier post.
Some people seem to say you can run a 30A, others say they run no fuse because the amperage normally varies from as little 1.5A running to 20A starting depending on rpm. I run nothing. |
The Following User Says Thank You to Entropy11 For This Useful Post: | ||
Thanks!
HEI moduals can fail and leave you on the side of the road waiting for a tow truck.
Points/CD always can work. You can have a new use ed/not needed condenser under the cap. CD fails, hook it back up and drive home. Points do not really wear with CD ignition. |
My MSD module has been working perfectly for 10 years. I don't carry a backup. |
Entropy, do you have a link to that relay?
5 PACK 40/30 AMP 12 V DC Waterproof Relay and Harness - Heavy Duty 12 AWG Tinned Copper Wires, 5-PIN SPDT Bosch Style Automotive Relay https://www.amazon.com/dp/B074FSZWVT..._hI8hEbA98P0GV You could run a 4 or 5 pin I believe. I grabbed the 5’s for whatever reason. You can wire them as positive or also ground trigger for other applications and there is a normally open and normally closed terminal. The diagram above uses the normally open terminal. You can usually hide these somewhere so they’re not noticed, and also pull the relay out and toss it in your pocket if you store your car somewhere and worry about it. Cheap simple anti-theft lol. On my latest addition (‘68 GTO) it was the pink/black stripe and black/yellow stripe (I think). It was only the other week but I’ve since done so much with that car and wires I forget... haha, sorry. |
You can also get the same thing through Pertronix (PN: 2001). I think they charge $35-40 (for 1). Their install instructions give some insight, but the colors they reference below won’t match up with every install.
https://static.speedwaymotors.com/pdf/4472001.pdf |
