Old 01-16-2020, 04:48 PM
sd331c sd331c is offline
Default Help with turning light issue.
Hello I am new to this forum and need advice with my 67 GTO. (Stumped) When I turn on my parking lights or head lights both turning signal lights on dash come on solid green! When I hit the switch to signal left or right they blink as they should but will stay lit! Car is stock original wireing and has not been altered. Any input on ware to start would help. Thanks in advance
Old 01-16-2020, 07:10 PM
tigergto's Avatar
tigergto tigergto is offline
First thing I would do is check and clean all grounds.
Old 01-17-2020, 09:39 AM
Thank you for the reply! I have checked all grounds with a multi meter and a electrical device called a cat and mouse! Motor to Firewall, Frame to Chasie, Grounding Bar under Dash All Checked Out. fuses are All good. Ware should I go from here? Thanks
Old 01-17-2020, 10:27 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Do you have the correct bulbs in there? Should be 1157's I believe. Double filament bulbs. Also as mentioned, make sure the lamp housings them self are grounded.
If they are not grounded you will get feedback and do weird things.
64 Lemans hardtop
4spd, buckets
Old 01-17-2020, 11:58 AM
Jonsie Jonsie is offline
Headlight switch swapped out recently?
Old 01-17-2020, 02:37 PM
Thank you for the reply yes you are right all 1157 . Brake lights work/ Parking lights work/ Left and Right turn blinker works front and back. But when I turn my running lights on or headlights on both left and right dash signal lights come on solid Green! They will blink when signaling left or right. But will remain lit solid green. When I turn my lights off they go out and work as they should! I never checked ground at the sockets but I will. dont know if the lights would com on if there was a socket ground problem. I am open for sugestions. I disconected the battery for now cant take a chance. No won has altered any thing all wireing still has the factory raped cloth black tape under the dash. I am open for sugestions.
Old 01-17-2020, 03:12 PM
tigergto's Avatar
The dash signals come on, do the exterior signal bulbs also come on when turning your lights on?
Old 01-17-2020, 03:34 PM
4GTOSplus's Avatar
4GTOSplus 4GTOSplus is offline
The dash cluster may be letting light from the dash pod show through the signal lens. Pop out the dash light sockets from back of dash pod except for the turn signal lights. Turn on lights, see if it changes.
Old 01-17-2020, 07:01 PM
No it is Factorie / Original. Bought this car when I finished High School from a local Pontiac Dealer It was 3 years old. Never drove it mutch, never seen snow, rain sense I have owned it! Then went to collage, then started a cariere U get the picture took it out once a year or so. Now retired and have been driveing it off and on. But this problem just started out of the BLUE! All wireing stock, Still has the black cloth tape on the dash! I hate to start ripping things apart going blind! Need a direction to start! I will try to attach a photo of my son and the car. He just got back from a 1 year deployment in Irac and has never drove it I figured it would cheer him up. Any help on this would be great.
Old 01-17-2020, 07:17 PM
Wow I will look to see! Witch one is the pod cluster. I will look under with a big mirror . But when I turn off my running lights or head lights both green turning lights go off. Thanks I will try to get my head under the dash and see. Thank you. Will let you know. And go from there.
Old 01-17-2020, 07:33 PM
Yes they are on that is what we use to call the Parking Lights! BUT I have not looked to see if they go out when I turn on the head lights! Will check and let you know. Boy thank you. I rather go step by step with you all one thing at a time. Than just taring things apart.
Old 01-17-2020, 08:20 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Two things I would search for, one there should be a 3 wire loom that exits out of each of the front turn signal lamps. Two of those wires are 12 volt power + wires, one is to turn on the marker lights and the other is 12 volts + to turn the TS blinker light(s) on. The last wire (one per each housing) is a ground wire. I would check those sockets as well as the ground wire on both sides. The ground wire runs over to the core support. On 66 and 67 GTOs it is very common for those turn signal housings to rust and fall apart from the inside out. Often one or both of those housings need replaced due to rust in the socket where the bulb plugs in. (Those TS housings will hold water when the gasket for the lens leaks.)
After that you need to check the ground wire underneath the dash, that wire is a black wire & it is attached to the back of the gauge housing.
The end of the ground wire looks like this:
Here is a pic of the ground wire from the 2 bulbs which light up your green turn signal arrows. If that ground is OK. Next you need to check the ground strap/brace at the back of the gauge housing. It's right beside where the speedometer cable attaches to the back of the speedometer.
I can post a photo of the ground bracket if you need me to.
Name:	1967 GTO Rally Gauge Dash Factory Ground Wire for the TS arrows.jpg
Peter Serio
Owner, Precision Pontiac
Old 01-17-2020, 08:44 PM
Old Goat 67's Avatar
Could be just what Peter is talking about in those front turn signal sockets. You could test that by just running a jumper wire from ground to the bulb housing body on each side.
Rather than spend $90 a piece for those reproductions, I took the ground wire and soldered it to the housing and covered it with shrink wrap.
ID:	529018   Click image for larger version
Old 01-18-2020, 09:23 AM
4GTOSplus's Avatar
Default Lights
[QUOTE=4GTOSplus;6101395]The dash cluster may be letting light from the dash pod show through the signal lens. Pop out the dash light sockets from back of dash pod except for the turn signal lights. Turn on lights, see if it changes.
Didn't think of this before, do the signal lights in dash dim when you turn dimmer on headlight switch? May be simple but try it,
Old 01-18-2020, 10:13 AM
Thanks for all the electric info! The grounding stake on wire looks small! Yes can you please post a pic of the grounding Bracket! I am printing out all the Suggestions and will start with the easy ones first and start (Ringing) it out from there! regards Don
Old 01-18-2020, 10:27 AM
This will definitely be on my go to list! A big thanks to you all !!
Old 01-18-2020, 10:39 AM
Yes parking/signal lights come on when when I pull the light switch once and go out when I pull the detent switch all the way out! Green dash turning lights stay on all through the above until I push the light switch in.
Old 01-18-2020, 10:44 AM
The same scenario caused by the bad grounds up front could also be caused by the rear bulb sockets. Four more places to look for a bad ground to each socket.
Old 01-18-2020, 10:56 AM
Its on my to look for list! Wow the list is getting long Big thanks to every one. Will update when I (Ring Out) each one.
Old 01-18-2020, 12:16 PM
Front parking lights going OFF with headlights ON is factory. Turn indicators ON with headlights ON (no front parking lights) pretty much rules out a feed back problem caused by a bad ground up front.
This would have me in the back looking for a problem. Bad ground would be first on the list then bogus sockets or bulb/s not grounding good in the socket/s.
Rear bulbs will light up with a bad ground. Current gets divided up through other bulb filaments. Lower watt bulbs, like turn indicators, can light up from this power hunting ground.
Clay
