Old 02-04-2020, 09:41 AM
cyber104 cyber104 is offline
Default One noisy lifter on startup and sometimes restart........
Hi All:
Have any of you guys experienced 1 noisy lifter on startup?
I have about 1000 miles on a fresh build. If it matters, the cam is a mild Lunati and the lifters were supplied in their kit. The engine is basically a stock Pontiac 400 in my '78 TA.
Sometimes in the morning when I first start it up - one lifter ticks for some time - sometimes it's 10 seconds - yesterday it was for about the first 2 minutes of driving the car.
This also happens sometimes when I run errands and leave the car sitting in the parking lot for 10 or 15 minutes. On restart I sometimes get a tick for 3-5 seconds.
I'm running Shell Rotella T4 15W-40 and I get 20 lbs. of oil pressure per 1000 RPM when the engine is warm until I hit the pump relief at about 58 lbs.
On cold start oil pressure is an immediate 50 lbs.
The ticking always goes away - but it's a bit annoying. Is this just "the way it is"?
Thanks,
Chris
The Following User Says Thank You to cyber104 For This Useful Post:
Old 02-04-2020, 10:06 AM
1969GiPper 1969GiPper is offline
Just a thought. Are you sure the tick is coming from a lifter? Could it be an exhaust manifold gasket leaking which can have a tick type sound that lasts only a few seconds?
The Following User Says Thank You to 1969GiPper For This Useful Post:
Old 02-04-2020, 10:14 AM
I hadn't really considered that but it's certainly easy enough to see if the bolts are tight.
I would think that would only apply when the engine is cold - but I get this "tick" even on hot restart after the car sits for 15-20 minutes - so I assumed it was a lifter leaking down.
Thanks,
Chris
Old 02-04-2020, 10:41 AM
steve25 steve25 is offline
Does the motor have its stock Exh Manifolds?
Old 02-04-2020, 10:57 AM
New Ram Air Restorations manifolds.......
Old 02-04-2020, 11:41 AM
Ok, so no possibility of a leaky heat riser then.
Pull the oil filler cap off and the tube to the air filter from the valve covers , then get a lenght of 3/4" heater hose and listen into each valve cover while someone else restarts the motor and you will for sure hear if it's coming internally from a rocker, or a Exh leak.
Old 02-07-2020, 11:51 PM
ta-kid ta-kid is offline
Try a 5 w-40 oil and see how the lifters react.The 5w oil will flow the best when cold and if it’s a hydraulic lifter leak down issue it should stop ticking almost instantly.If it works move up to a 10 w-40 if you feel more comfortable with that weight of oil.
The Following User Says Thank You to ta-kid For This Useful Post:
Old 02-08-2020, 08:33 AM
shaker455's Avatar
shaker455 shaker455 is offline
Originally Posted by cyber104 View Post
Hi All:
Thanks,
Chris
Chris,
Rotella T no longer has enough zinc in it so you have to put an additive like Lucas Engine Break-in additive always.
If your running without additive now your doing damage.
I have encountered the same as well and some can be quieted down with a lash adjustment and some noise can be attributed to the brand or type rocker arms being used.
As long as they pump up and noise goes away after some operation I would not chase it too far.
Jeff
Carburetor building & modification services
Servicing the Pontiac community over 25 years
Old 02-08-2020, 09:07 AM
68 Firebird's Avatar
68 Firebird 68 Firebird is offline
Default oil viscosity
I had the some lifter noise at startup with heavier oils in the colder months. Since switching to VR1 10W30 noise has stopped! Viscosity at startup is a player. Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, GM HEI and Ram Air pans and RARE Long Branch Manifolds
The Following User Says Thank You to 68 Firebird For This Useful Post:
