Tri-Power Tech 57-66 Tri-Power Talk
Old 02-07-2020, 06:27 PM
konwal455gto konwal455gto is offline
Default 2004r with Tripower
Hello, I am paring a 65 Tripower to a 2004r and I think I have a problem with the tv cable geometry . It runs fine 1st, 2nd, 3rd. 4th and overdrive. At WOT it will only shift out of 1st if I let off the throttle. Thanks Bill
Old 02-10-2020, 01:49 PM
mike w mike w is offline
You are correct! The setting (not adjusting,) of the TV cable is critical. Years ago, I assisted in designing a TV cable system for the tripower. They are sold on this webpage.
www.bowtieoverdrives.com
Take a look.
You can ruin your transmission with an improper adjustment.
Mike Wasson
pontiactripower.com
Old 02-23-2020, 03:46 PM
Thank You . Bill
have it ordered
Old 04-27-2020, 08:51 PM
Default The Final conflict 2004r with tripower
See the street section for the problem solved ! 2004r with 3 ducks is well worth trouble ! konwal455gto
