Old 02-15-2020, 03:19 PM
66pmd428's Avatar
66pmd428 66pmd428 is offline
Default Which AFB Carb Base Gasket?
When choosing a carb base gasket, do you want to match the manifold or the carb? The manifold has the 4 hole square bore pattern and the carb is pictured below. Some of the base gaskets are either 4 hole, open, or 4 hole and have slots or small holes punched in them. Kinda confused about this
Old 02-15-2020, 03:24 PM
carbking's Avatar
carbking carbking is offline
ALWAYS best to use the CORRECT, ORIGINAL gasket specified by the manufacturer for the carburetor against the carburetor.
A second gasket matching the above to the intake MIGHT be necessary if the original carburetor application and the intake application are different.
Jon.
Old 02-15-2020, 03:41 PM
66pmd428's Avatar
Thanks for the reply Jon. That's part of the problem I think, because the carb is not original to the manifold. It is an aftermarket Offy manifold and the carb is a 4242s off a pontiac. If you do not have the original carb base gasket how do you know which is correct for the carb since there a couple to choose from? I guess I'm trying to figure out if I will be covering up any air passages that shouldn't be if I just use a 4 hole gasket.
Old 02-15-2020, 03:58 PM
Kenth's Avatar
Kenth Kenth is offline
1957-65 Pontiac AFB´s uses the one to the left, #1A-124.
1966-67 Pontiac AFB´s uses the one to the right, #1A-226.
1960 (Special) and 1961 Tempest Super Duty uses #1A-119 with the preheating slot ahead of the primary ports and steel baffle on top of gasket.
The 4242S is a 1967 Pontiac 400 Carter AFB.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-15-2020, 06:31 PM
carbking's Avatar
Kenth - Carter shows 1967 to use 1A-256.
Jon.
Old 02-16-2020, 04:54 AM
Kenth's Avatar
Jon, correct, no picture in the Carter manual of the 1A-256 flange gasket.
Since the 1966 and 1967 Pontiac AFB intakes are much the same i have found the 1A-226 works well on the 1967 intake manifold.
Do you have a picture on the 1A-256 gasket?
Thanks, Kenth
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 02-16-2020, 12:45 PM
carbking's Avatar
1A-256 is 1/4 inch thick. Resembles 1A-226, but without the 4 bleed holes.
Jon.
