Ames Customer Satisfaction Forum Post a 'current' compliment, suggestion or issue with regard to an Ames service or product.
Old 02-18-2020, 06:07 PM
360Rocket's Avatar
360Rocket 360Rocket is offline
Default Engine turned dash, Help needed
So I got my engine turned dash and console inserts and everything lines up EXCEPT the insert for the dash. It hangs over the dash at the bottom by at least an inch. Is this by design? Am I supposed to trim this? and how can I get a clean straight line if I need to trim it? Pics below.
Old 02-18-2020, 07:58 PM
360Rocket's Avatar
part number correct? for a 1970?
Old 02-19-2020, 06:42 AM
Ram4king's Avatar
Ram4king Ram4king is offline
I'm sure you have to trim it. You realize that's not a factory decal right?
That's not supposed to be there.
Old 02-19-2020, 07:14 AM
steve v's Avatar
steve v steve v is offline
It looks like they used the original woodgrain applique as a template for this custom piece you have. The woodgrain wraps under the lower part of the bezel, if this part you have doesn't bend you'll have to cut it to fit.
Old 02-19-2020, 08:28 AM
360Rocket's Avatar
It would be nice to have something that tells you that, some kind of instruction sheet? photos? something. Hopefully the tech support guys will see this and give me some direction?
Old 02-19-2020, 10:12 AM
Stuart's Avatar
Stuart Stuart is offline
You may get a faster response by calling Ames and asking for technical support.
Old 02-19-2020, 10:55 AM
AMES-TECH's Avatar
AMES-TECH AMES-TECH is offline
Ames Tech Staff member
Can you please PM me with your customer # or invoice #? The part number does show to be correct for all 70-72 except convertible.
[/SIGPIC]
Old 02-19-2020, 03:42 PM
360Rocket's Avatar
sent
Old 02-19-2020, 06:14 PM
360Rocket's Avatar
Its actually a thin sheet of aluminum. It would be a much easier deal to rectify if it was vinyl but it would not be as nice a piece. And yes I know its not NOS, never owned an NOS car I like a bit of personalization.
Smilies are Off
