Closed Thread
Old 02-20-2020, 01:48 PM
Mean Green's Avatar
Mean Green Mean Green is offline
Default Moroso 'Langer' pan
What are the benefits of the Moroso split rail pan? How is it better than a Canton or Milodon pan?
I have one on an engine I own. It's going in a tube chassis car, so fitment isn't an issue. But it would be nice if I could use this engine in my other car with a factory subframe too.
I just finished modifying the factory subframe and putting in a removable center tube. I really don't want to redo it to fit the pan.
www.lancablingsolutions.com
Old 02-21-2020, 01:55 PM
Mark G Mark G is offline
Pain in the ass using that pan. Get a good stef pan JMO
Old 02-21-2020, 01:58 PM
GTO's Avatar
GTO GTO is offline
Loved my Langer pan! Split it a few times to check pump, bearings etc. You won't go wrong. …. Eric.
Runner Up Q16 Norwalk 2013!
Old 02-21-2020, 02:04 PM
slowbird's Avatar
slowbird slowbird is offline
I personally found the Moroso pan to fit quite a bit better than the Stef pan did.
There is no comparison between the Moroso and Canton/Milodon. Those are just stock type pans
Old 02-21-2020, 02:42 PM
Mean Green's Avatar
I screwed up when I cut out the center of the cross member. I made it wide enough for the split rail pan, but I assumed the pan was centered on the engine, but it's not.
Guess I'll swap the pan and pickup if I ever put the engine in my factory subframe car.
Old 02-21-2020, 06:31 PM
If it's built right nothing to check .It does not make you faster your proof of that..lol
Old 02-21-2020, 06:36 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Anybody got pics of the Langer split pan?
Not in my case Stef pan fits way better .. Made no different performance wise just shinier..lol
Old 02-21-2020, 06:50 PM
GTO's Avatar
GTO GTO is offline
Talking
When you go fast. You hurt parts. Maybe you'll find out one day. Check my signature. LOL.
Old 02-21-2020, 06:51 PM
GTO's Avatar
GTO GTO is offline
Did you try both?
Old 02-21-2020, 07:00 PM
Bnick166's Avatar
Bnick166 Bnick166 is offline
If interested....I got a polished Stef's pan I'll part with.
Old 02-21-2020, 07:30 PM
Mean Green's Avatar
Here's a couple.
ID:	532644   Click image for larger version
Old 02-21-2020, 07:38 PM
GTO's Avatar
GTO GTO is offline
My old pan.
ID:	532646   Click image for larger version
ID:	532647   Click image for larger version
ID:	532648   Click image for larger version
ID:	532649   Click image for larger version
Old 02-21-2020, 07:39 PM
GTO's Avatar
GTO GTO is offline
Last one.
Old 02-21-2020, 09:38 PM
slowbird's Avatar
My Stef's fit like crap around the timing cover. Everyone has their own experiences with products
Old 02-21-2020, 09:44 PM
John Langer's Avatar
John Langer John Langer is offline
There are around (3) versions of the "Langer" pan. The split pan was the result of crower having a bad run on lifters where they manufactured the wheels out of a material that was too hard. At the time, crower was the only manufacturer that would make lifters for a Pontiac that were .904 in diameter. Before the split pan, it would take me upwards of 3 hours to pull out the broken lifter, drop the pan, clean out all of the broken parts and put it back together. I lost a race due to not being able to fix it in time so I made a split pan. Now, I can change a lifter in around 45 minutes. Since I worked with Jessel on lifters, knock on wood, haven't had any issues.
Old 02-21-2020, 10:11 PM
Very True
Old 02-22-2020, 12:08 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
The Stefs pan needs some additional baffling in the sump area if you're going to spin a big stroke "4.5" over 6800-7000 rpm.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 02-22-2020, 12:11 AM
RAIV-Z's Avatar
You can get the Langer split pan with a few additional mods to fit a titan oil pump and both a robbmc "long" starter and a powermaster stubby.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 02-22-2020, 12:23 AM
Bnick166's Avatar
This pan will fit a 4.250 Crank. Custom built by Jake. 7 Quart pan. Provisions for 1/2" NPT oil temp. gauge fitting.
Closed Thread
