THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Folks - I installed a used high-beam T3 headlight in my ‘67, only to have it start fogging up, or smoking inside when turning on the head-light. Any reasons why this would happen?
Thx, Rob |
Probably got a crack in it somewhere. Just a guess. Sealed beam lights only work in a perfect gas filled vacuum...or something along those lines.
Greg Reid Palmetto, Georgia |
Over the years they lose vacuum where the electrical contacts pierce the glass in the back. No or reduced vacuum means almost instant failure. I've tested about a dozen used or NOS originals, about 70% of them smoke up on the first use.
The Following User Says Thank You to dataway For This Useful Post: | ||
50+ YO used bulbs aren't worth the hassle,
it's hit or miss and the weak (yellow) output sux if you drive around sundown/night. I have been using these for decades with little/no issue; https://www.lectriclimited.com/lighting-fuse-flashers JM2C Cheers.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. ![]() |
The Following User Says Thank You to Jeff Hamlin For This Useful Post: | ||
I have had about a 50% failure rate with old sealed beams. Before buying them, I require them to be tested.
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 ![]() 2019 Canyon SLT Crew 4X4 ![]() |
The Following User Says Thank You to 77 Canamman For This Useful Post: | ||
In testing nearly a dozen NOS '68-'71 T-3 low beams, only have had one that tested bad. all but three, I removed from NOS headlamp mtg panels, at least a 45 years old parts stock. Need to go through remaining milk crates of used T-3's, am sure there will be chunkers.
Coronavirus... Get another one.
A friend of mine says to put a drop of super glue on that pinch point on the back of the bulb.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
