Old 03-24-2020, 01:46 PM
Old Goat Racer's Avatar
Default 69 disc brakes
I know a guy who wants to put front disc brakes on his 69 Cat.
What are his options ?
Everybody knows somthin.
Nobody knows everything !
Old 03-24-2020, 01:59 PM
Single piston caliper late '68 -70 Pontiac B series disc spindles/calipers/rotors are out there, not sure what the availability of new rotors is for them today.
Old 03-24-2020, 03:25 PM
rustyrelic rustyrelic is offline
Yup, 69 -70 front spindles. And yes, I think it will hard and expensive to find rotors. Believe Scarebird has a kit?
Old 03-24-2020, 03:26 PM
Yup, 69 -70 front spindles. And yes, I think it will hard and expensive to find rotors. Master cylinder for the 69-70 disk car. Believe Scarebird has a kit? I think I should have also installed a residual valve as when I finished, it seems like the rear gets too much whoa as compared to the front.
Old 03-24-2020, 08:51 PM
sorry -we do not anymore.
They were extremely slow sellers and required different components than the earlier kits.
Old 03-24-2020, 09:54 PM
Check with Master Power. I believe they have a kit that will work. It's pricey($1800) and requires the use of 17" wheels. OE rotors and calipers are still available through RockAuto(Raybestos parts). He might want contact Steve Snyder @ CO Pontiacs, Frank's Pontiac Parts or Steve Barrack(Pontiac Heaven) to see if either of them have a '69 or '70 with the complete system still in place.
Dr. Thomas Sowell
Old 03-25-2020, 10:51 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
The parts stores all list rotors available, but if you check the part number they give you it's a 4.75 on 5 bolt pattern and not correct for these cars. No one is making the original rotors that fit these cars to my knowledge.
Best thing you can hope for is finding a late '68-70 B body with disc brakes in good shape that is getting parted or junked.
Old 03-25-2020, 11:13 AM
mr67gp mr67gp is offline
CPR sells rotors for the '67/'68 cars. Not cheap!
https://www.ebay.com/itm/1967-1968-P...P/264395338506
Jim K in PA
1967 GP HT 428
1967 GP convert 428
1957 Chieftain 4D HT
Old 03-25-2020, 01:58 PM
Every source I’ve looked up lists two different wheel lug bolt patterns for ‘67-‘70 “B” bodies: 5 X 5 (like my ‘64 Catalina) and 5 X 120.7mm(5 X 4.75). One more case of measuring before buying.
Dr. Thomas Sowell
Old 03-25-2020, 04:08 PM
David Brown's Avatar
David Brown David Brown is offline
Send a message via ICQ to David Brown
I am so glad I bought a couple NOS rotors years ago when they were still available and not ridiculously expensive for my 70 Bonneville.
Old 03-25-2020, 05:13 PM
Ben M.'s Avatar
While I'm sure you are correct that the sources say that, I have never seen a 1967-1976 B-body with anything other than 5 on 5 bolt pattern. The application listing in many cases lists the wagon version as the 4.75 on 5, which I know should be wrong having owned a half dozen over the years. I did this conversion myself 15 years ago and back then the 4.75 on 5 was NOT listed as a viable source by any of the old books or computers. The bearing sizes between the two are not interchangeable to fit the smaller bolt pattern rotor on the spindle of a big car (I tried both a '70-81 F-body and a '71 A-body).
In 1977+ I know the 4.75" on 5 bolt pattern was the standard and only heavy duty suspension cars got 5" on 5, making finding brakes for them an exercise in fun.
Old 03-25-2020, 07:56 PM
I had a conversation with Nunzi maybe 15 years ago before disc brake conversion kits became available for the ‘61-‘64 “B” bodies. If I remember correctly Nunz said that to convert a ‘64 to disc brakes you had to use a ‘70 “B” disc brake setup. because it used the 5 X 5 (5 X 127mm these days) bolt pattern. I do remember he was VERY specific about the donor being a ‘70.
Dr. Thomas Sowell
Old 03-25-2020, 10:20 PM
marxjunk marxjunk is offline
i dont really think 400 for a pair of rotors is expensive...the ones from CPR
i paid $278 a piece for my CTS-V to put it in perspective
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 03-26-2020, 06:50 AM
Hangn69 Hangn69 is offline
Kore3 hubs
Old 03-26-2020, 11:38 AM
I actually agree! Compared to the cheap $50 chinesium rotors on ebay, I would gladly pay for NOS rotors. Luckily I also stockpiled a bunch years ago when I found a stash for sale from a closed parts house in NE PA.
Jim K in PA
1967 GP HT 428
1967 GP convert 428
Old 04-04-2020, 06:56 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
Buy my 70 bonneville lol.or maybe will be parting it out sometime. Has 3.23 posi and 455 ho in it
Illinois Outlaw Gassers
6.27@107
9.97@131
