Old 03-28-2020, 12:17 PM
muscle_collector's Avatar
Default HOW ABOUT A WEIRD AND ODD CASTING THREAD
pulled an engine out of a car yesterday and noticed these upside down castings. I have seen different things like this over the years. what do you guys have?
interesting thing about these they were cast on different days and both are upside down. anyone have an idea why?
Name:	62 cast heads upside down 1098.jpg
ID:	535566   Click image for larger version
Name:	62 cast heads upside down cast 1108.jpg
Old 03-28-2020, 12:33 PM
grandam1979 grandam1979 is offline
1970 455 as cast,
Old 03-31-2020, 11:05 AM
John Milner's Avatar
John Milner John Milner is online now
The original engine in my '69 GTO has 62 heads with the numbers upside down like that.
Old 03-31-2020, 12:10 PM
tom s tom s is offline
I had a RA V 400 block with a transfer lug on it,no clue why?I have owned quite of few and never had seen that before.Tom
Old 03-31-2020, 07:39 PM
I saw a picture yesterday on another forum cant remember which but the guys engine had 62 heads cast upside down just like these. had completely different cast dates. so who knows on that one.
Old 03-31-2020, 09:37 PM
gtospieg gtospieg is offline
was working on a(302) 69 Z yesterday and the drivers side head date code was upside down
Old 03-31-2020, 11:51 PM
242177P's Avatar
242177P 242177P is offline
Some 67 intakes have "FIREING ORDER".
The Following 2 Users Say Thank You to 242177P For This Useful Post:
Old 04-02-2020, 01:02 AM
Brian Baker's Avatar
It can all be chalked down to human error when they were setting up the molds prior to pouring.
Old 04-02-2020, 12:03 PM
Masters of creativity in the Race Section here :
Edelbrock Aluminum Angle Plug Heads - with factory casting numbers.
These 1968 #96 Ram2 heads even have date codes on them.
1972 7F8 heads
1973-74 SD heads
Name:	aluminum -96- heads 2.jpg
ID:	536097   Click image for larger version
Name:	aluminum -96- heads 3.jpg
ID:	536098   Click image for larger version
Name:	72 aluminum e-head decoy.jpg
ID:	536099   Click image for larger version
Name:	72 aluminum e-head decoy2.jpg
ID:	536100   Click image for larger version
Name:	aluminum -16- heads 2.jpg
Old 04-02-2020, 03:01 PM
I have seen upside down "62" heads as well and I had a set at one time. I have also seen big valve screw in stud small combustion chamber heads with no casting numbers, just a blank pad. The cast dates were in the 1970 production year. At the time, I thought they may have been service heads, but I later saw heads where the casting numbers were ground down and a production casting number was stamped in. The surface texture appeared to be original, so I think somebody forgot to put the casting numbers in the tool when casting the heads. Has anybody ever seen D-ports like this?
Here is another oddity. I had a set of #31 heads that came off of a car I junked a long time ago. One head had the same casting style as the early 1968 16s and 670s and the other one had the later 1968 style casting. The heads were only about two days apart, and came on the same car. I don't have a scanned image but I still have pictures somewhere I took in the 1980s.
Old 04-06-2020, 05:57 PM
necdb3's Avatar
necdb3 necdb3 is offline
I have the original "62" heads on my 69 firebird 400 conv. The 62 is correct on both heads but the date code on one is K148, the other is K188. Only the K188 is upside down.
Old 04-06-2020, 06:10 PM
thepontiacman's Avatar
I bought some 1970 #64 heads that were upside down. I recognized it, but before that had never seen it before.
Date codes were '69.
I sold them at some point.
