Hello,
Just finished rebuilding my rear seat with blasted/primed seat springs/frames, new burlap, cotton, foam etc, and new covers. Finished the seat bottom 3 days ago and finished the seat back last night. Looked them over once more this afternoon before I put them in storage (car still not painted) and I see 3-4 of the heat pressed vertical seams on the backrest have let go and it looks like total crap...to say I am disappointed is an understatement. After some close inspection I see what appears to be a manufacturing defect. I can see that the pressure or heat that was used on the affected seams to bond them through the foam and to the back panel was less than the others that are still holding, as you can see the shape of the simulated stitching on the good seams while the ones that let go have almost no embossing at all. Complicating matters is that I purchased the complete interior kit 4 years ago and due to change of jobs and other life issues just started on the interior last week ![]() Anyone seen this happen before? I will contact the manufacturer next week to see what they might be willing to do for me. Thanks
Michael 1970 Oshawa built 1 option Judge. 24 year restoration/upgrade project finally finished! 1979 Trans Am - low-buck drag car project for when I retire |
Yep. Probably PUI? I had the same problem years ago... they wouldn't do anything about it. Went with Legendary. Problem solved.
"I know just enough to keep me here, but not enough to get me out" |
OK thanks, I'm at least comforted to know someone else has seen this.
I'd rather not name the manufacturer until I give them a chance to help but I will update this thread when all is said and done. Thanks
So you don't have to completely scrap them, maybe an upholstery shop can sew the pleats into the covers- kinda like a wide pattern of tuck and roll- and make them look good?
Maybe an option vs. losing money on them...
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
Wow. That's disappointing. Good luck on trying to get a replacement set after 4 years. All you can do is plead your case and see.
Triple Black 1971 GTO |
The manufacturer responded the next day to my email, and said they would replace the cover once production resumed.
Very happy for their quick response and standing behind their product, and will update the thread once it is received and installed. This may take awhile ![]() Thanks
That's sounds like a reasonable response, especially given the time frame. Now just hope that it happens relatively quick.
Better than the response I got from the co. I bought my brake booster from. The m/c was bad, of course like a lot of car guys it sat on the shelf for a year after I bought it. They said since it was so long that I was SOL. |
The Following User Says Thank You to TAKerry For This Useful Post: | ||
