Old 04-16-2020, 01:23 PM
necdb3's Avatar
necdb3 necdb3 is offline
Default 69 firebird fender
I read through some old threads about poor fit of 69 fenders. Have they improved them? Has anyone put on a set recently and can speak for current production? Looking for both sides.
Old 04-16-2020, 04:20 PM
JLMounce JLMounce is offline
Anecdotally I have not heard that they have improved. If you're buying a repop, expect to have a body shop spend a decent amount of time getting them "right."
That said, they aren't monumentally terrible. It's not like they just don't go into place. Where you'll typically have trouble is the alignment to your headlight surrounds and the radiator support. If the car is primarily just a driver, or fun weekend cruiser, you (and basically all passer byes) aren't really going to notice it. Not unless you're being really nit-picky.
If the car is a show car and it's gaps an alignment need to be perfect, it's going to be an issue. So it really depends on where you want to spend the money. You can try and find NOS fenders that are going to fit better and require less work at the body shop, but cost an arm and a leg. Or, you can purchase repops which are much cheaper, but will require much more work at the body shop.
It's basically a pick your poison type situation.
-Jason
1969 Pontiac Firebird
Old 04-17-2020, 07:15 PM
maxepr maxepr is offline
Default Fender
I've done a couple, had to cut and push front down to get it to line right for the headlight. One I had to cut 5 or six spot welds back to get the hood curve. do able. Last two i pieced two fenders together and patched on my own, Takes time but well worth it... Ron
69 Firebird 350 HO 4spd Black survivor
Old 04-19-2020, 06:43 AM
necdb3's Avatar
What brand fender did you use?
