Old 05-01-2020, 08:44 AM
spectramitch's Avatar
spectramitch spectramitch is offline
Default 1969 Weatherstrip Install
I am going to be reinstalling my roof rail weatherstrip channel today on my 69. (The stainless pieces that tape and screw into the upper door jam and hole the rubber ) I have the 3m tape stuff and weather strip adhesive. Is there any methods to installing the channel to make adjusting the door glass go easier? Or does the channel butt right up against the frame?
Old 05-01-2020, 11:26 AM
OG68 OG68 is offline
Theres a slight amount of adjustment allowance built into the channel. You need to have the windows in and partially adjusted to make the final set of the upper weatherstripping together with the final window adjustment. This is detailed in the Fisher Body manual chapter 6, Doors, A body Front Door Window Adjustment and Side Roof Rail Weatherstrip Adjustment
Old 05-01-2020, 11:39 AM
Ben M.'s Avatar
Ben M. Ben M. is offline
Ditto OG68. The factory service manual is pretty good at detailing the install.
Once you've done it once or twice you get the hang of it.
Old 05-01-2020, 04:33 PM
Thanks for the help and pics, i got it mocked up pretty good. I had the drivers window out so it seeds adjusting.
