We've gone round and round on jack types, colors etc. But I was having a discussion of the exact position that the lug wrench and jack stalk were stored. We are fairly sure we know how that is, but if you have some pics to post that would be great.
That lead us to another question that concerns the storage of the spare. Why did GM choose to stow the spare upside down. To me this seems to be counter intuitive to adding air to the spare. Can anyone think why GM did that. I guess that maybe owners rotated their tires often enough including the spare so adding air to it was at this stage? |
The spare was mounted facing down because of the bolt. The bolt is too short to mount the tire facing up even though the bolt is already very long. I'm certain that if the bolt were any longer it would not allow good clamping force.
Shorter anchor bolt, and lower center of gravity?
Here you go Andre. Customers were probably asking that same question for a few years then Pontiac offered this option. I put one in, looks nice and easy to check spare air pressure.
The Following User Says Thank You to 65 421 TODD For This Useful Post: | ||
Ours has always had the longer bolt (since 1970 at least which is when we got it). Maybe the original owner of ours was one of those who complained about the shorter bolt?
The '64 GTO The '65 Chevelle The '69 Chevy Pickup Project The Brazen Orange 2006 GTO |
I used to have a Craftsman News Binders from 1964-1978. Apparently that was a tidbit of information that I glossed over. On all my cars I have mounted the spare facing up. Mostly because I like to look at the pretty red line when I open the trunk. I'm fairly sure this face down method of storage was consistent across the GM line, and yes, a short J hook is less expensive than a longer one saving a few cents on each unit which does add up to significant $$, but could this have been the only reason?
It’s obvious how the Tempest Series storage was to been done.
The water slide decal on the underside of the deck lid clearly shows this. Both my cars (Baltimore and Fremont builds) are the same. The “Factory stamping” of the trunk floor also provides were the jack and lug wrench were to be placed. Chris.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
I've always stowed my jack in the latter position versus the early layout
per location change in '66 as well I store tire face up. I also use a salvaged post sleave from a '67 parts car, I like the idea of preventing possible vibration and choose to carry a matched tire/rim as spare since I drive it ![]() But thats just me. Cheers.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. ![]() Last edited by Jeff Hamlin; 02-26-2024 at 07:15 AM. |
The year 1966 of the Tempest Series showed a change in the storage of the jack mechanism, as Jeff mentioned above.
My records of “Original” decals on the underside of the deck lids show the change in the middle of March ‘66. First design decal - (horizontal decal) BAL 01A BF 01B BAL 03B Second design - (vertical decal) BF 03C PON 05C The first 4 photos below show my BF 01B with the early decal and the Fremont painted jack assy. and base. Last photo is a BF 03C with the later vertical decal. Chris. .
