Old 05-31-2020, 05:24 PM
dataway's Avatar
dataway dataway is offline
Default Wheel barrow flat tires
I'm getting tired of replacing the wheel/tire on my wheel barrows, landscaping cart, power washer etc. etc. .... no matter what I do these things won't hold air after five years. Well ... some of them seem to last forever, another of the same brand won't last two years.
So fed up I'm actually going to try to dismount and fix a couple tomorrow .... but is there any better solution? Maybe something I can fill them with that will firm up like foam and make them semi-rigid?
Old 05-31-2020, 05:55 PM
Sirrotica's Avatar
Slime works for quite awhile, I've used it before in some of my lawn equipment tires.
And then there's inner tubes.
And finally, expanding foam insulation, although I've never used it, plenty of videos on You tube drilling holes in the tire and filling it with foam.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 05-31-2020, 06:19 PM
carbking's Avatar
carbking carbking is offline
Have had luck with inner tubes.
Slime has not worked well for me.
The key if you just use tubeless tires is to glass bead and paint the inside bead on the wheels prior to installing the new tires.
Jon.
Old 05-31-2020, 06:41 PM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
I have used a tube in both my wheel barrels and have done well for me, only topped it off with air.
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
Old 05-31-2020, 07:29 PM
242177P's Avatar
242177P 242177P is offline
https://www.harborfreight.com/13-in-...hub-60250.html
Old 05-31-2020, 07:36 PM
tigergto's Avatar
tigergto tigergto is offline
Inner tubes are always my fix for that problem, works well.
Old 05-31-2020, 07:59 PM
Murf Murf is offline
I replaced the tire/wheel on 2 wheelbarrows with the tires that don’t use air. They have a semi solid ring inside. Worked good for me. YMMV
Murf
Sent from my iPhone using Tapatalk Pro
Old 05-31-2020, 08:01 PM
Murf
I couldn’t read 242177P’s link on Tapatalk but that’s what I used.
Old 05-31-2020, 09:37 PM
nashcar nashcar is offline
Tubes, problem solved.
69 Z 302 M21 3.73
http://www.byjanmarie.com/camaro/Z28.html
69 FB 400
http://www.byjanmarie.com/firebird/69.html
69 Camaro 327 4sp. 4.10
http://www.byjanmarie.com/camaro/69camaro.html ( SOLD)
2002 Camaro LE/SLP-(sold)
1967 Nova SS-- 327, M20, 3.73, FRT Disc
Old 05-31-2020, 09:55 PM
dataway's Avatar
All of these that I have problems with already have tubes .... and I changed the Schrader valves too.
Might have to get me some of those solid tires. They seem to be a popular item.
Thanks for the excellent suggestions folks.
Old 05-31-2020, 11:20 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Did this a while ago, now has solids, no air no flats. Cost may be a little bit more, but no worries.
64 Lemans hardtop
4spd, buckets
Old 06-01-2020, 01:20 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Hmm... wheelbarrows now have tubeless tires?
Old 06-01-2020, 06:55 AM
sdbob sdbob is offline
Yes tubeless. I had one 4.5 cut ft plastic-vinyl wheelbarrow used around the house. Sat outside year round,tire was always a problem. So found tubeless tire at Tractor Supply been fine. Just did another Saturday for wifes little barrow,tire from HF. Havent done one on hd steel, concrete wheel barrow yet. My hd cub cadets front tires have tubes.
Old 06-01-2020, 08:04 AM
carbking's Avatar
The issue with keeping the tires up, is then you have to use the wheelbarrow!
Jon.
The Following User Says Thank You to carbking For This Useful Post:
Old 06-01-2020, 09:10 AM
When the 'speaker of the house' talks-orders you got to react!! Gulp!
Old 06-02-2020, 03:19 AM
dataway's Avatar
So ... while I was relaxing in the shop repairing the two flats ( found small punctures in the tubes) .... I remembered something I would use as a kid to fix flats.
They were patches that you clamped on to the tube with a small clamp and this metal plate that you would light on fire ... the plate had some kind of single use fuel in it that would heat up and "vulcanize" the patch .... they worked tremendously.
Is that my imagination or did those exist?
Old 06-02-2020, 08:11 AM
carbking's Avatar
They existed. The ones I remember were oblong in shape. After we were no longer able to get them, used to light the glue; basically served the same function.
Jon.
Old 06-02-2020, 09:17 AM
TAKerry TAKerry is offline
I am a contractor and nothing more frustrating then grabbing the wheel barrow with a flat tire out of the storage yard on the day of a concrete pour. I put solid tires on mine. The one I have looks just like a reg. tire, but is solid rubber. Its been so long I cant remember where I got it. Either at Tractor supply or maybe Northern Hardware. Never have to worry about a flat again.
Old 06-02-2020, 11:14 PM
fyrffytr1's Avatar
I did away with the wheelbarrow and got a four wheeled dump wagon that I can either pull by hand or, flip the grab handle around and hook to my riding mower. Being old I got tired of fighting to keep the wheelbarrow from tipping over.
I have had it for about 5 years without a flat tire yet. If I have a problem with any going flat I will put hard rubber ones on.
Old 06-03-2020, 01:55 AM
I replaced the entire wheelbarrow with a solid tire model. One less headache.
