Old 06-02-2020, 08:17 PM
6t5gto 6t5gto is offline
Default Washer hose connector
Looking for the white plastic nipple/connector for the washer hose for a 65 GTO. It connects the 2 piece washer hose at the battery location.
Old 06-02-2020, 08:56 PM
oldgoat16's Avatar
oldgoat16 oldgoat16 is offline
Post Connector
I believe our host sells that kit in white
Old 06-02-2020, 09:58 PM
I did look in the catalog but did not see it. Please let me know the part # if you come across it. Thanks
Old 06-03-2020, 08:47 PM
JohnnyAction JohnnyAction is offline
Hello, The part you are looking for is not being reproduced, and is not available through any of the parts suppliers. The part that was referenced in post #2 most likely is the washer pump repair kit in white. The original part number for the connector is 9780771, however has long since been discontinued. I was able to source this part off a junk 1965 Lemans at a local salvage yard. If you locate a car with the original washer hose intact, be sure to take the washer hose retaining clip located at the front corner of the left fender by the battery. These clips are also very difficult to locate. You can also check your local Craigslist adds for anyone dismantling one. Good luck, John
Old 06-03-2020, 09:01 PM
John, I was able to find the washer hose retaining clip about 2 years ago but still looking for the hose connector. The ones I have found have been brittle and not useable. Thanks for the info and let me know if you want to sell you connector.
The Following User Says Thank You to 6t5gto For This Useful Post:
Old 06-03-2020, 09:04 PM
John, What years did this clip come on?
Old 06-04-2020, 10:43 AM
Hello, I believe the connector was only used on the 1965 models. Another person you could contact for an answer to this question and possibly a source for the part would be Lee Barnes / Barnes Classic Restoration 864-414-2929. Lee not only has restored many GTO's to high standards, he has been a judge at many Pontiac and GTO shows. He is a great guy to deal with, and will surely try to help you. John
Old 06-04-2020, 02:31 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
It’s not just 65.
1964 - 1967 if you have a V-8 and washer option.
This is the plastic connector needed to splice the two washer hoses.
Chris.
ID:	541757   Click image for larger version
Old 06-04-2020, 02:36 PM
Chris, Can I buy it from you?
Old 07-06-2020, 02:56 PM
Still looking
Old 07-20-2020, 05:54 PM
Default washer hose connector
Found and bought
