Old 06-15-2020, 12:18 AM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
Default 1967/68 F-body Pedals
is the brace that supports the brake pedal on a automatic car, is it the same for a clutch/brake brace, with the only difference being the pedals assembly?
Jim
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
Old 06-15-2020, 08:40 AM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
Yes. The mount is the same.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 06-15-2020, 09:11 AM
leeklm's Avatar
leeklm leeklm is offline
Confirmed. PO had installed clutch & brake pedals in my 68. I bought an automatic brake pedal and swapped them out - piece of cake.
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight
Old 06-15-2020, 01:36 PM
thanks!
Jim Moshier
1962 Catalina 389
