I wonder why is it that Pypes systems only offer a offset/offset mufflers on thier systems? I called them and asked them of they offer something different and couldn't a answer. I used their system on my T-37 and i hated the sound from the race pros, too me it sounded like muffled glass pack. I would rather use a center/center muffler, too me, their are already enough bends in the exhaust. I have a set of Hooker aero chambers and i love the way they sound. This is the same engine is different cars.
https://youtu.be/z_pQviGPQSg https://www.facebook.com/10000482443...4198374084303/ Last edited by se428bandit; 07-07-2020 at 11:47 AM. |
I would think most muffler suppliers and manufacturers have catalogs that would be of help. They typically show length, width, shape, and inlet/outlet placements.
I suspect the Pypes muffler is simply matched to fit the car application as factory and makes it easier with a known muffler that works with whatever exhaust system that is chosen. Just for fun, check out Summit. They have photos. These are all 3" https://www.summitracing.com/search/...-in%3A3-000-in |
More pictures of my former Goat: http://www.barrett-jackson.com/appli.../w_search.aspx My old car is listed in the 2007 Scottsdale Auction, Lot #1016 - $60K And in the 2008 Scottsdale auction, Lot #960 - $80K Eventually sold by Brighton Motor Sports in Scottsdale, AZ -$89,900 |
A lot of people think of muffler flow as a straight line or stream. It's not. The modern chambered mufflers uses a plenum at either end and relies on the pressures of the exhaust pulses to flow and scavenge while the baffles generate sound cancelling waves back towards the incoming sound waves.
The location of the outlet relative to the inlet is a matter of the best position for the pipes for ground clearance and clearance to shocks and rear axle. in most cases, the maker locates the pipes where the OEM hanger mounts are. On an A Body, that is usually offset inlet and center outlet.
Triple Black 1971 GTO |
Actually, the muffler configuration on the factory A-bodies I've dealt with have always been offset/offset. That keeps the head pipes closer to the center of the car so they can somewhat tuck up into the trans tunnel for clearance, and it keeps the tailpipes moved to the outside so they clear the upper control arms.
Any time I've tried installing an offset/center muffler configuration I've had to rebend the headpipes to tilt the mufflers to the outside of the car, so the tailpipes would clear the upper control arms. A factory style hanger will also want to have the muffler over in this position. This is likely why almost all of your exhaust kits are designed like OEM with an offset/offset muffler in mind. Like 78W72 mentioned, the good flowing mufflers on the market don't have bends inside, they are a straight through design. If you use a chamber style muffler like the Hooker, it doesn't really matter if you use a center/center configuration, with the sound chambers inside the air flow is going all over the place anyway. Give's them a unique sound but they generally restrict a bit compared to the straight through design like Dynomax, Pypes, etc... I agree I don't like the sound of the Pypes race pro's. I've switched a couple over to the street Pro's and was much happier with it. But my go to muffler of choice are the Dynomax Ultraflows. |
I had to add a 1-2" section on my Torque Tech pipes at the top to use a offset/center muffler on my 78 TA as they were set up for offset offset but that would have hit the electic fuel pump I had mounted using offset/centers.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
