Old 07-12-2020, 12:43 PM
Rlfehl's Avatar
Rlfehl Rlfehl is offline
Default 64 GTO Steering column assembly...What am I missing?
64 GTO steering column. This was apart when I got it and am not sure how it goes together and what I am missing. I know there should be a spring in there but nut sure. I can't find a good diagram. I also am not sure how the wheel connects to the horn ring...or maybe it doesn't because it is mixing years. See the pics for what I have.
As always, thanks for any help you can give!
ID:	544834   Click image for larger version
ID:	544835   Click image for larger version
Old 07-12-2020, 12:53 PM
Horn contact plate so far
Old 07-12-2020, 01:00 PM
Old Goat Racer's Avatar
This should be what Chief is talkin bout
Everybody knows somthin.
Nobody knows everything !
Old 07-12-2020, 01:12 PM
Rlfehl's Avatar
Thanks! I do not have one of those...is there a spring that goes in there also?
Old 07-12-2020, 03:08 PM
The horn contact plate is the tan piece you see.
This is a '65 set up but I believe they are the same or very similar for '64.
Old 07-12-2020, 09:20 PM
Rlfehl's Avatar
Thanks Chief!
Old 07-13-2020, 08:23 AM
Andre's Avatar
Andre Andre is offline
I believe you are also missing the red or tan plastic hollow round insulator with 3 holes on the circumference and the 3 screws that connect the horn bar to the steering wheel along with that flexible horn contact plate. I don't remember the "biscuit" horn contact switch being used in 1964, though since the wheel is the same a 65, you could just use it and skip that horn contact plate.
Old 07-13-2020, 08:04 PM
John V. John V. is offline
See diagram for the '64 Deluxe Wheel from the MPC.
Looks like you already have Items 10, 11, & 12 installed, the spring loaded Horn Contact parts.
I have a tilt column and not sure how it differs from a non-tilt column.
But there is a spring Item 22, called the Upper Bearing Steering Shaft Spring.
Not sure if that should be visible in your pic but looks to me like it should be located thru Item 13 the Cancel Cam and around the end of the Steering Shaft.
Item 14 is the Horn Contact Ring but is described as part of Item 13.
Not clear to me if your cancel cam includes the H.C. Ring.
After those parts are in place, the Wheel goes on.
Then the Horn Ring Spring goes in. The one posted by Old Goat Racer looks like the one illustrated for the Standard Wheel (the wheel using the center horn button, not the Deluxe horn ring).
Item 8 for the Deluxe Wheel looks different and also requires Item 7, the Horn Ring Pivot Ring.
Then the Horn Ring goes on, Item 6 which you have.
You also have Item 1, the Horn Ring Ornament.
But before the Ornament is pushed in, you need Item 5, the Spacer Bushing with the Item 4 screws plus Item 3 Washer and finally Item 2, the Nut which it appears you have.
Old 07-13-2020, 08:13 PM
Here is a pic I found in a search.
Shows the correct Item 8 Horn Ring Spring and the Item 7 Horn Ring Pivot Ring from a '64 GTO Deluxe Steering Wheel.
Name:	GTO Steering Wheel.jpg
Old 07-13-2020, 09:16 PM
Item 7 Horn Ring Pivot Ring for the '64 GTO Deluxe Wheel p/n 763323 according to the '66 MPC. This should be it. Don't find it reproduced.
https://www.ebay.com/itm/NOS-GM-57-6...ss!30705!US!-1
Old 07-13-2020, 09:19 PM
The '64 GTO Horn Ring Spring shows p/n 765631.
Try this:
https://www.ebay.com/itm/NOS-GM-1955...0AAOSwwgVd-Qa8
Old 07-13-2020, 09:26 PM
The '64 Horn Ring Spacer Bushing, p/n 764762 according to the MPC for the '64 GTO Deluxe Wheel:
https://www.ebay.com/itm/NORS-55-70-...QAAOSwtLpdVs90
Old 07-13-2020, 09:33 PM
And finally this if you don't have it, the Steering Shaft Upper Bearing Spring, p/n 5673012:
https://www.ebay.com/itm/Steering-Co...0AAOSwMste7Mlp
Way easier to find these parts than I expected, '64 only for the GTO but apparently other usage within GM make them a little more common than one would think.
Old 07-14-2020, 12:21 AM
Rlfehl's Avatar
Thanks Andre and John. I think that I have all of the parts coming now.
