Old 07-13-2020, 03:09 PM
crustysarge crustysarge is offline
Default Cheap flex fan runied 10th T/A hood
Next time you think about a cheap rotating part take a look at this. Belongs to a guy I know here in Italy.
ID:	544914   Click image for larger version
ID:	544915   Click image for larger version
The Following 4 Users Say Thank You to crustysarge For This Useful Post:
Old 07-13-2020, 03:14 PM
Years ago Ford had that problem with their OEM fan blades. I learned not to stand bent over the fan with the engine running.
Old 07-13-2020, 03:50 PM
Joe's Garage Joe's Garage is offline
Default I witnessed one of the Ford fans disassemble themselves on a friend's 5.0 mustang.
It was about thirty years or so ago.
He had just installed new mufflers and (I think) a new, open-element air cleaner.
There were about six of us standing around the front of the Mustang chatting.
He had the hood open and he was revving it up so we could be impressed by the 'new' sound.
His final rev was probably to around 6k and the fan let go.
Fan blade glanced off the hood and landed about 50 yards away, behind us.
Water pump exploded with antifreeze all over the place. Lower hose was shredded.
Water pump pulley jammed down between the timing cover and the crank pulleys and stopped the engine instantly.
Alternator was spinning about 100k RPMS - sounded like a siren. Took about two minutes for it to slow down and finally stop.
I've had a healthy respect for all fans ever since. Especially at any kind of RPMs.
The Following User Says Thank You to Joe's Garage For This Useful Post:
Old 07-13-2020, 03:52 PM
charlie66's Avatar
I had an alternator fan come apart on two different occations. One time it went right through my 1964 gtos fender . Looked like as if it got shot by a shotgun . Second time was 2 weeks ago it cut the lower radiator hose almost in half and cracked the paint on the hood with a big dent I dont like standing by the fender anymore when messing with the throttle. Most people dont give it a second thought..
Imagine that hood was open and someone was stanging there! (SMH) Not good!
My Half AN Injun.....
Old 07-13-2020, 04:19 PM
Navy Horn 16 Navy Horn 16 is offline
That sucks!!
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, [email protected] in the quarter...still tuning.
Old 07-13-2020, 04:22 PM
gtohunter's Avatar
gtohunter gtohunter is offline
Had something similar happen where I worked. Maint tech came to me stating that a large 6' diameter axial flow fan was vibrating badly and shaking the structure. I ran out there with him and it was running smooth as silk, and was about ready to tear into him a little when I noticed fan blades impaled into the ground, the side of a building and some time later found two blades on the roof of an adjacent building! I was so glad that he came to get me when he did, and not stood there and continue to watch !
Jimmy M
68 GTO
Old 07-13-2020, 04:24 PM
grandam1979 grandam1979 is offline
My buddy had that same thing happen to a 70 Torino with the scooped hood his made it all the way out. Very sorry to see that happen to you.
Old 07-13-2020, 04:30 PM
72projectbird's Avatar
I've seen quite a few cars in the junkyard with cheap fan blades thru the hood.
Quite the amount of force behind those things.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 07-13-2020, 04:37 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My Chevelle buddy had that happen to him on his BBC!!
Skip Fix
Old 07-13-2020, 07:48 PM
PDC PDC is offline
I saw this exact thing happen with a buddy’s ‘76 Trans Am when I was in high school. Went through the hood like a can opener. That was back when you could find a 70-76 TA hood at the salvage yard for under $250.
But no doubt - the lesson here is don’t spend unnecessary time under the hood of a running engine. Setting the timing at idle is risky enough.
Old 07-13-2020, 07:55 PM
Steve C. Steve C. is offline
Related, and already eluded to...
Years ago if they used a mechanical fan, many Winston Cup teams used a inexpensive stock four-blade Ford fan. This four-inch Ford fan, originally built for truck years ago, was proven to be the most efficient and economical mechanical fan on the market. Many teams used it for short-track. The type of track often determined type of fan, for the super speedway most preferred to use electric fans because of the horsepower and fuel-efficiency advantages. Same today on many street cars.
Side note- I think the article meant to suggest 4-inch blades. But not sure.
Old information here:
Old 07-13-2020, 08:36 PM
I had a similar aftermarket steel fan blade go on my 75 Camaro back in 78. Just cruising about 45 mph. Took out the radiator and put holes in the shroud. Never used another one.
Old 07-13-2020, 08:46 PM
Scott65's Avatar
Scott65 Scott65 is offline
Knew a guy growing up that came within 10 minutes or less of severely injuring or killing his best friend. The fan when through the hood about that long after Doug had been standing over it with a timing light... Close call.
'65 Tempest 467 3650# [email protected]
Old 07-13-2020, 08:53 PM
WOW!
More proof, you get what you pay for.
Too bad, it appears as though it is a nice car.
Old 07-13-2020, 11:47 PM
charlie66's Avatar
Both times the fan gave warning and i ignored it. Never again. Next time ill know to just change it out for a new one..
I hope your friend was ok...
Old 07-14-2020, 02:01 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
I'd like to think that the crease in the flex blades of that fan create stress risers, causing cracks to start after enough flexing. The reason I'd like that: because then I'd be more comfortable with the curved blades on the flex fan I just put on the Pontiac in my GMC!
Old 07-14-2020, 10:07 AM
mgarblik mgarblik is offline
The few OE failed fans I have seen all failed at the rivets that held the blades. But all the OE fans I have seen have cupped blades and not the sharp creases like the one in this thread. When a blade does come apart, the potential for damage and injury is very high. The fan I just installed in my 62 Catalina is a 19" 1970 Oldsmobile clutch fan. The blades are a 2" pitch, cupped design. stainless steel blades riveted to a steel hub.
Old 07-14-2020, 10:17 AM
Formulajones's Avatar
Wow, I didn't think people were running those things anymore.
https://youtu.be/XqEydRRRwqE
Old 07-14-2020, 10:30 AM
HWYSTR455's Avatar
I thought everyone knows not to run those, but guess some people swear by them.
Old 07-14-2020, 10:44 AM
Skip Fix's Avatar
My buddies was not a flex fan it was a replacement form OReily. He was OK hood was not got a big dimple.
I had a buddy with a 70 TA have a belt let go and dimpled his hood. I'd never heard of that, then a few months later my 78 did the same thing!
Skip Fix
