Old 07-14-2020, 02:54 PM
balmfort's Avatar
balmfort balmfort is offline
Default DIY Restoration of AC hoses
Hey PY forum, I'm investigating getting the AC reinstalled in my 63 GP. I have all the original parts. Hoses need to be replaced due to cracking and some splitting.
Looking for advice from people who repaired their own hoses. Looks simple to me, where did you purchase the replacement hose material?
Staying with R12 and have the original worm gear hose clamps.
thanks- phil
Phil
'63 Grand Prix / 389 Tri-power
Old 07-14-2020, 06:42 PM
LATECH's Avatar
LATECH LATECH is offline
Worm gear hose clamps are a failure waiting to happen.
Get hoses made with shells that are crimped/compressed to the hose/fitting.
Find an AC shop that has a crimper and a supply of hose.
Old 07-14-2020, 06:55 PM
mgarblik mgarblik is offline
If you have a Parker Store in your area, they should have the hose, and if you choose, they can put the crimped ends on the hoses as well. If you insist on maintaining the worm screw type clamps, make sure the bodies are in good shape and lubricate the worm screw mechanism before installing. Worm screw clamps for AC have the tang that helps trap the hose on the barbs. Worm screw clamps came from the factory on these cars and I have seen R12 stay in these systems for decades, but if the exact correct original look isn't super important, crimped ends are certainly better. If you ever change to 134A in the future, worm screw clamps don't do very well. The smaller molecules of 134A will make their way out of a worm screw clamp system in good condition in a couple years.
Old 07-14-2020, 08:07 PM
My local parts house was able to make mine for me.
Old 07-14-2020, 11:37 PM
george kujanski's Avatar
I've done it, bought the hose, crimp ends, and a crimper. It was years ago, and I bought the stuff online. did a search. The crimper was the most expensive piece, but i had a few cars I was going to convert to R134A
George
Old 07-15-2020, 04:12 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
AS LONG AS you stay with R-12, the OEM worm-drive clamps work just fine. Give the clamps a good inspection, looking for thread distortion from having been previously over-tightened. If they look good, use them.
The hose you need is "standard barrier", not reduced barrier which is thinner wall. For the compressor discharge use #10 (1/2") and for the suction side #12 (5/8"). Here's a vendor with the stuff you need: https://coldhose.com/hose-by-foot/st...rier-hose.html
I did exactly this with my '66 GTO back in 2012 and haven't had to add any refrigerant yet, so this is definitely a viable solution.
Old 07-23-2020, 08:30 AM
balmfort's Avatar
what did you do about replacing the insulation foam on your hoses and the muffler? I cant seem to find this material from any AC hose & component vendors?
Is it really needed beside keeping originally?
thanks - phil
Phil
Old 07-24-2020, 12:35 AM
hgerhardt's Avatar
thanks - phil
Nitrile foam pipe insulation was used where the lines come close to the fender to prevent rubbing and also help the muffler to work better. You can get it from McMaster and Amazon, even Home Depot. Key is to get nitrile foam rubber and not polyethylene. It's called 'pipe insulation'.
