Old 07-19-2020, 02:01 PM
FMile Pontiacs's Avatar
FMile Pontiacs FMile Pontiacs is offline
Default 05 Silverado front brakes are dragging
I'm having a problem with the front brakes dragging or sticking. First I changed
the front calipers, rotors and pads but both calipers are still dragging. I can open the line from the master cyl to bleed of and it frees the brakes and allow it to be driven again untill I apply the brakes a couple times and then the dragging is present again. By this time im thinking it must be the master cyl so I changed it and the brake booster. The brakes are still dragging so I changed the front rubber lines. I have also tried disconnecting the abs electrical connections but that hasn't helped. What is the problem? I have spent a lot of time and money but no positive result as of today. Joe
Old 07-19-2020, 04:01 PM
fyrffytr1's Avatar
Have you checked the proportioning valve?
Old 07-19-2020, 04:22 PM
I couldn't find a proportioning valve. They may not have one on the ABS equipped trucks?
Old 07-19-2020, 06:00 PM
67drake's Avatar
67drake 67drake is offline
I may be wrong, but do the pads set inside the frame that is bolted to the steering knuckle, then the Caliper slide over the pads? I forgot as my wife sold her ‘03 a few years ago. But I remember I had to actually clean the corrosion up with a file as a wire brush wouldn’t even budge the rust. The pads kept hanging up in that frame. Just a thought
‘55 Catalina
Old 07-19-2020, 06:04 PM
Scott Thelander's Avatar
might be time for hoses ..... just went thru this with my motorhome
1988 454 33 000 miles
was it doing it b4 you did the work ?
Old 07-19-2020, 06:44 PM
Sirrotica's Avatar
This isn't an uncommon problem after searching the net a bit. I copied and pasted another 05 owner that sounds like the same situation as yours.
05 Silverado.. I had the same problem with the fronts locking up after driving a few miles and not even applying them on long stretches after having replaced pads,shoes, wheel cylinders, front calipers,hoses and master cylinder. Flushed lines completely twice. Checked booster by removing vacuum line and using long nylon pull tie as a dipstick to verify there was no fluid present as others have noted. After reading many blogs and the mention of possible ABS problems without the light on I removed the ABS fuse, drove about 5 miles and the brakes were locking up and cool. Replaced the fuse and drove another 5 miles, braking alot and letting the truck come to a natural stop in neutral to see if it was still partially locking up and there was no indication of it locking up. Felt the fronts and there were not hot as they were earlier in the day when I drove it just a short distance. Would let it come to a normal stop coasting in neutral with no indication of a problem. Even stopped on slight inclines and it would then roll backwards after coming to a stop. Have not had the problem since and feel more could get the same results should they try this. Wish I had of thought of it or read it somewhere long ago to save myself alot of frustration. Hopefully others will benefit.
There was also a mention of a defective MC that leaked into the power brake booster causing the issue, but because the problem was isolated to just a small run of trucks there was no recall on it:
I have 2006 of same truck and had same issue. If you have been adding brake fluid over the past year, pop the hose off the booster. Check in there and see if you see fluid in the bottom. I had this on mine, so replaced booster, master (leaking in booster), new pads and calipers as they roasted on mine. Flushed all the lines and been working great.
One more that replaced the booster and solved the problem:
SOLVED!!!!! Well it is finally fixed and I drove it to work today to make sure. I drove it Saturday and it locked up so I loosened the MC and it released immediately. So, ordered a now booster for the same truck and they gave me one that was different. UUUGGGG This one had an adjustable rod on it. So installed drove and worked after a little adjusting. Drove it all day Sunday and to work today (43 miles one way) and not hot at all! Thank you all for your help.
Hopefully one of these things will solve your problem..........
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 07-19-2020, 07:43 PM
Thanks everyone for the replies. I have replaced the booster and master cyl also because of the brake fluid in the booster. I may try a another booster with the adjustable rod
Old 07-19-2020, 07:53 PM
Do you have a part number and brand name for the booster with the adjustable rod?
Old 07-19-2020, 08:27 PM
Sirrotica's Avatar
I just copied and pasted the replies I found verbatim, I have no idea of what brand or part numbers the guy used. I just know from a quick search that it is a fairly common problem, and seems to center around the brake booster that doesn't let the MC return all the way and residual pressure can't release causing the brakes to lock the more it is driven. The hotter the ambient air temperature was said to play a role too in some of the replies I ran across.
My personal take might be to try a shim/shims on the firewall to get some extra travel for the brake pedal. Or perhaps between the booster and MC. It would accomplish the same thing as an adjustable push rod.
Evidently the system is quite close to not having enough clearance as it was designed. As the truck gets miles on it the balance changes the wrong way causing this residual pressure due to too little/reduced travel of the components.
I personally have never worked on this problem, just getting some feedback from owners that have run into the problem, tried all the obvious fixes as you have and found out the problem is in the area of the booster.
Rock Auto has a bunch of them with notations, here's the link:
https://www.rockauto.com/en/catalog/...e+booster,1884
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 07-19-2020, 08:33 PM
thanks I will try to fix the problem sometime this week and post the results here. Joe
Old 07-19-2020, 09:30 PM
73LeMans's Avatar
73LeMans 73LeMans is offline
I drove an 03 GMC 2500HD for 10 years. Had the same problem of dragging brakes. Always bought NAPA brake components. It was the caliper bracket in my case. NAPA guys said for 95% of the customers with issues, the brackets solved them. Already mentioned here I know, but first hand experience, that's what fixed my issue. When you replace the calipers, buy them with the brackets. And of course, always check brake pad fitment prior to mounting. File the ears of the pad is they wont smoothly glided in and out prior to lubing them up.
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....and 2023....and 2024.....and 2025.....who am I kidding? there will be no 9s with this engine!
>>My 73 Build thread
Old 07-19-2020, 09:54 PM
Lightfoot's Avatar
Mark S,
Is the caliper bracket you refer to the same as some of the asian cars that have 'floating' pins that are encased in grease? Those are known to dry out and get seized. They will drag, but mostly cause rapid premature pad wear.
Don't know but the owner would notice difficulty getting new pads to fit in some cases, though.
I once had an experience with an '86 Chrysler FWD that all four wheels bound up from a miss adjusted rod in the power booster. That took me a couple of days to figure out.
Old 07-19-2020, 10:07 PM
67drake's Avatar
That’s what I was trying to describe. I couldn’t remember for sure if that was the truck it happened on as I’ve owned many.
‘55 Catalina
Old 07-19-2020, 10:40 PM
I just took a late night drive and the brakes started to drag bad I backed the master cyl nuts of about 3 full turns and the truck about ran off to leave me alone! I will shim it this week and hopefully be done with it if I can't find a booster with the adjustable rod.
Old 07-19-2020, 10:41 PM
3 Chiefs's Avatar
3 Chiefs 3 Chiefs is offline
I 100% agree with 67drake and 73LeMans. The pads slide in and out in a small track. There is a shim in that track and the pads slide within the shim. A small buildup of rust happens under the shim. This compresses the ends on the pads preventing them from sliding.
Remove the caliper bolts and set it aside. Then remove the bracket that holds the caliper.
If you have a bench vise place it in there.
Take a rough file edge or something similar and clean up that groove that the pads slide in. You can also put some brake grease or small amount of anti seize in the grove before you put the shims back in.
Also just so you know I believe most parts places carry these for about 20 bucks each. They will want your old ones for a core.
I have been through this and I bet this is your issue. Good luck.
Paul
I never met an old car that I didn't like.
Old 07-19-2020, 10:55 PM
thanks Paul I replaced the caliber brackets when I installed the new calibers and pad fit was good I believe its the booster but I won't know until later this week and I will post the results. Hopefully all this information will be helpful and save someone a lot of labor and money. I'm already around 700.00 in this little project doing the labor myself.
Old 07-19-2020, 11:39 PM
fyrffytr1's Avatar
Can you tell us more about the truck? Is it a crew cab or heavy duty, 4 wheel disc brakes or front disc rear drum etc?
Old 07-19-2020, 11:52 PM
RAIV55 RAIV55 is offline
My '02 Silverado had a similar issue on the rear calipers. The brackets have a coating that swells when rust develops under it. Pealing the coating off and blasting the rust off the area where the anti-rattle clips sit, and lubing with caliper grease cured mine (for now).
Monty Frerichs
B&M Machine
Box Elder SD
Old 07-20-2020, 09:58 PM
The truck is a 2005 single cab 4 wheel drive 5 speed with the 4.8 front disc and rear drum
Old 07-21-2020, 02:07 PM
SRR's Avatar
SRR SRR is offline
Default This:
You have found the problem. Not enough brake pedal free play. Sounds like the booster isn't going back to it's fully retract position.
― Calvin Coolidge
