I have researched this and have not found a satisfactory answer so I thought I would just ask everyone. I have a 65 GTO with a 69 428, 5 speed, 3.36 gears, and a Vintage Air system. I am running an aluminum radiator, good water pump with good clearances, and a Flex-A-Lite 7 blade fan with a factory shroud. I have never had any issues with overheating. As a matter of fact the engine runs around 180 degrees most of the time. I have the idle RPM set at 700. Then on July 3rd the local nursing home had a cruise-by car show for the residents so we took the GTO. It was in the low 90's and very humid that day and we were in stop and go traffic and never exceeded 5 MPH. We had the air on and the temperature shot up and pegged out the gauge, not good. Once we got out of the traffic it instantly came back down to 180 degrees, still running the air.
I have since then sealed up the stock fan shroud to the radiator with foam to ensure that the air will only be pulled through the radiator. I have the Holley Sniper EFI and can set it up to where the idle RPM increases when the air is on which would increase the air flow through the radiator as well as make the water circulate better. My question is what would be a good RPM to increase it to. During my searching I found that the recommended idle speed for a 69 428 with a manual transmission is 1000 RPM with or without the air on. I was thinking of pumping the idle up to 1100 RPM with the A/C on which is the RPM the EFI uses to warm the engine up. What do you guys think would be a good RPM to start with? I really don't want to make any other changes, like a different fan, because what I have works really good. Even idling for extended periods in the garage with the A/C off it rarely gets above 180 degrees. I am thinking that with the A/C condenser mounted in front of the radiator that when the A/C is on the added heat from the condenser is pulled through the radiator making it even hotter. My last choice would be to put a dual electric fan system on it and let the EFI control the fans, but I would want one that is a direct bolt on and comes with the shroud that fits my radiator. Thanks for the help, Dale
1969 428 Tremec 5 Speed U.S. Army Retired Retired Helicopter Pilot |
i have air and fitech on my 70gto with electric fans. if you dont want to change what you have maybe add a pusher fan controlled by both AC on signal from the vintage air AND a set temp on your EFI. simple relay control can use both signals in order for fan to turn on. you will need a trinary switch on the AC to control fan. EFI usually completes ground on control side of relay when programmed temp is reached.
Steve |
Thanks for the response, Dale
My normal idle speed is around 850 for a nice lope, but I have the electric solenoid on the carb set to increase the idle to around 1,050 RPM with the A/C running. Helps a little with engine temps but it also seems to keep the A/C outlet temps in the car a little cooler when sitting at a light. A little extra air flow through the condenser and radiator is never a bad thing.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. |
Thanks for the information, Dale
