I have a 1968 with deluxe interior and am preparing to install the TMI Products one piece molded headliner. I am not sure how to remove the polished metal interior trim piece the runs from the top of the A pillar to the bottom of the rear quarter window where it meets the body panel.
Any help or direction to pictures or video is much appreciated.
"Pride Precedes The Fall" 1968 Firebird Undergoing Transformation 1970 Formula 400 - Keylime Green, Stroked to 462 Cubes - Gone But Forever Remembered 2016 Mustang GT - GT with the Performance Pack, beats my former 12 Boss around the track. |
Are you referring to the stainless Steele channel that holds the window weatherstripping?
If so, you have to remove the weatherstrip first. Then remove the Phillips head screws. Lastly, there is some black butyl type tape attaching it to the body. However, I'm not sure you need to remove that for a headliner change. If not, post a picture of the piece you working with. I'm basing this off of how my '69 was setup. |
I am pretty sure those are just held in with spring clips. I do not remember having to unscrew anything, they just pull off.
But it has been 8-10 years since I had those apart. |
Yep. Pretty sure those are just clips and pop them out.
- Mike ![]() '69 Firebird 400 - Goldenrod Yellow, 455 +.060, '6s-7' heads, Comp Cam 276AH-10 (51-309-4), TH400, Ford 9-inch w/3.08, 800cfm Q-jet, Stock Intake, Hooker Headers, Flowmasters '68 Coronet 500 Convertible - Medium Gold Metallic, stock 318 +100,000 miles |
