Old 08-17-2020, 09:13 AM
Stickman77 Stickman77 is offline
Default 17" wheels '65 GP
Will 17x8 wheels with a 4.5 backspace fit on a stock '65 GP with fender skirts?
Tires will be 225 or 235 width. Thanks
Old 08-17-2020, 06:17 PM
389 389 is offline
Bad move putting a short sidewall tire on the suspension that positive cambers during compression (braking). You'll end up with half the tires contact patch on the pavement.. These cars need thick sidewalls. At least take the alignment out of the 60s and switch the caster to positive and the camber to negative while keeping the numbers the same..
Old 08-22-2020, 12:00 PM
ben3843100 ben3843100 is offline
There’s an entire thread on here on what will and won’t fit on the back of a ‘65-‘66 car. I personally have tried both 17x7 4” offset and 17x8 4.25” offset and the 17x8” with no skirts were very, very close to the fender lips. Unusable in my opinion at that offset. I currently have 17x7 4” offset and they fit all of the way around with no rubbing and 235/60/17s with factory drums out back. With my new disk brakes out back I get a small amount of run in a hard corner or in a offcamber parking lot entrance due to the rotors moving the wheel last out about 1/8” each side.
As an aside I have aftermarket tubular upper control arms with taller balljoints and stiffer springs, bushings and sway bars all around so it handles very well.
Old 08-26-2020, 11:50 AM
1970ls5's Avatar
1970ls5 1970ls5 is offline
Very nice 2+2 and the wheels were very tastefully done! Dave
The Following User Says Thank You to 1970ls5 For This Useful Post:
Old 09-03-2020, 11:01 AM
mrrat1 mrrat1 is offline
Wow that's a sweet 66'!!
The Following User Says Thank You to mrrat1 For This Useful Post:
Old 09-03-2020, 11:51 AM
428goat 428goat is offline
Wow looks great
The Following User Says Thank You to 428goat For This Useful Post:
Old 09-04-2020, 11:31 AM
Ragtop Man's Avatar
Ragtop Man Ragtop Man is offline
Sweet Jesus - that is dead solid perfect. Wow.
The Following User Says Thank You to Ragtop Man For This Useful Post:
Old 09-12-2020, 12:46 PM
marxjunk marxjunk is offline
skirt hardware really limits the tire width..i have 20x9 with 5 in back space, and fills the well very nice
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
