Old 08-20-2020, 07:17 PM
indiantony indiantony is offline
Default Alternator wiring
hello,I want to connect the wires to my alternator but the terminal ends got cut off.I have 3 wires:Green ,Brown and Blue,the Brown and Blue are taped together and the green is separated. On my alternator I have 3 lugs:
Bat, R and F
Where do the wires go?
Tony
Old 08-20-2020, 08:49 PM
OG68 OG68 is offline
Blue to F
Brown to B
The only green wire I see goes to the headlights.
http://www.wallaceracing.com/MWire5765-337.jpg
http://www.wallaceracing.com/wiring-diagrams.php
2007 Cadillac SRX
Old 08-20-2020, 10:39 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Green is temp sensor.
Old 08-23-2020, 08:42 AM
Thanks for your help guys. I want to replace the voltage regulator and horn relay,where is the best source to buy these?
Tony
Old 08-23-2020, 01:25 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default Voltage regulator 1963 Tempest or Lemans
I have this one, it's for sale if you want. You could PM me.
Name:	DELCO-REMY Voltage Regulator 1963Lemans_PYs.jpg
ID:	547791   Click image for larger version
Name:	DELCO-REMY Voltage Regulator 1963Lemans_PYs~.jpg
ID:	547792   Click image for larger version
Name:	DELCO-REMY Voltage Regulator 1963Lemans_PYs~1.jpg
ID:	547794   Click image for larger version
Name:	DELCO-REMY Voltage Regulator 1963Lemans_PYs~2.jpg
Peter Serio
Owner, Precision Pontiac
Old 08-24-2020, 08:43 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Default internal voltage regulator alternator
I bypassed the voltage regulator and installed a later model, internal regulator alternator. Increased the amperage and eliminated the external voltage regulator problems. Lectric Limited supplied the conversion kit and it works great.
https://www.lectriclimited.com/conve...-harness-88179
