Old 08-22-2020, 10:35 PM
65gto69's Avatar
65gto69 65gto69 is offline
Default Cost to re-chrome 65 GTO rear tail panel and the tail light bezels????
Hi guys,
Looking for an idea of how much it would cost to re-chrome the center rear ribbed tail panel and the tail light bezels on a 65 GTO?
Mine are not horrible but do have some pitting, not bad for an east coast car.
Also if you know anyone who does a good job at redoing these pieces.
I was going to send to Paul's Chrome because they are all I know of from watching My Classic Car.
Thanks for your help,
Mark
1965 GTO: 467 (Built By Dan Willever), 400 Block, Eagle 4.25 Stroke, Eagle 6.8 Rods, BRC Pistons, Custom Grind Hydraulic Roller Cam, Edelbrock 72cc Heads Ported, HS Rockers, Doug's Headers, Edelbrock Victor 4150, QTF 850 Carb, AutoGear M22 4 Speed, SPEC Clutch and Pressure Plate, 12 Bolt 3:73 Posi.
Old 08-22-2020, 11:07 PM
tom s tom s is offline
I looked into doing a 63 GP tail panel.The pitting had to be drilled,silver soldered filed flat and then the copper nickle chrome would be performed.It was thousands at the time.FWIW.Tom
Old 08-23-2020, 01:31 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Repo taillight bezel are $381.00 so unless your going for concourse numbers car
probably not worth sending them out. tried to see if Ames sells them but could not get on site. Not sure if anybody repo's the tail panel
https://pgclassic.com/gto65-216-gm-1...llight-bezels/
64 Lemans hardtop
4spd, buckets
Old 08-23-2020, 11:45 AM
ANDYA ANDYA is offline
Yep, the price to restore an original tail panel is very high. Understandable as it's alot of tedious labor. From what I understand some detail will be lost in the process. The solution is a high quality reproduction tail panel equal to the bezels.
Old 08-23-2020, 08:46 PM
Dick Boneske's Avatar
I don't know about '65, but the repro tail panel for the '64 is very good. I have one on my wife's car and it is much better in every way than the original on my car that was rechromed. I bought it for $850 about six months before the repro version was released.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 08-24-2020, 12:48 PM
65gto69's Avatar
Thanks for the all the responses.
If "THE PARTS PLACE" is the only supplier selling the repo 65 tail panel and it is not good, what other choices do I have but to pay the price and get mine redone.
I looked at the PG Classics website for the tail light bezels and they look really good, plus the positive comments from people who already purchased them. So I think that will be my go to option for the bezels.
Why is it so hard to reproduce that tail panel? They should have reproduce the tail panel and bezels at the same time. Even with no tooling to make the tail panel, why not use a factory original and make a mold?
Thanks again,
Mark
Old 08-24-2020, 01:42 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I would think demand for the part is some of it. Rechroming potmetal is labor and plating intensive.
Is the repop actually out yet?
Skip Fix
Old 08-24-2020, 08:48 PM
65gto69's Avatar
"The Parts Place" has a few left, but comments on it have been on the negative, but do not know what is negative about it. Is it appearance, is it lining up of the ribs with the tail light bezels, do the mounting studs not line up with the holes in the sheet metal.
Nobody seems to be saying anything other than they knew someone who purchased it and wasn't happy with it.
I may just bite the bullet and purchase from "The Parts Place" and live with whatever is wrong with it. My car is not concourse, I am just looking for something that has decent chrome, no pits, and the black white paint looks good.
Thanks,
Mark
Old 08-28-2020, 09:40 PM
Novice Goat Novice Goat is offline
Mine was not perfect. Some pitting but not too much. I had Dallas Plating in GA chrome it. Sanded/filled/painted the black parts myself. It came out good, not perfect if you look close, you can see imperfections. But good enough for a driver.
Old 08-28-2020, 10:26 PM
No pits is a lot to ask for!Tom
Old 08-29-2020, 04:57 PM
65gto69's Avatar
Thanks for the info.
What am I looking at price wise for a tail panel rechrome?
I would think it is over $1,000, but are closer to $1,000 or closer to $2,000?
Thanks,
Mark
Old 08-29-2020, 07:13 PM
So much depends on the shop,if they do copper nickel chrome on top of the repairs it will be a lot.Drilling the pits out and silver soldering them and filing smooth again is what kicks up the labor.Need to get it to a shop and get a bid.Tom
Old 08-29-2020, 07:51 PM
65gto69's Avatar
That is what I thought.
I think I will live with it for a couple more years as whatever is wrong with the shipping system right now, I don't want my parts floating around the worlds for weeks or months until someone gets them.
Thanks for the info Tom,
Mark
Old 08-07-2021, 08:13 PM
ZnbOlds455's Avatar
ZnbOlds455 ZnbOlds455 is offline
Mark, did you ever find someone to do your tail panel? I'm in the same boat with my 65.
Old 08-08-2021, 10:21 AM
propuckstopper propuckstopper is offline
Originally Posted by 65gto69 View Post
Hi guys,
Mark
This goes back some years, but there was a high end chrome shop in the Chicago area called The Finishing Touch. A prominent GTO restorer told me at the time that this is who he used for all his plating. He said even ten years ago a tail panel restore was in the $1500 to $2000 range.
I see they are still around: https://www.thefinishingtouchinc.com/
Old 08-08-2021, 10:42 AM
turbo69bird's Avatar
I don’t know much about this part but I can make a suggestion , chrome vinyl wrap can work really well on many fairly flat pieces. It may be worth looking at as an option. Chrome has gotten outrageous my expensive . This may be an option for some I’ve used it when wrapping airplanes and it looks just like real chrome .
960 HP @ 11 psi, 9.70 at 146.
Old 08-08-2021, 02:35 PM
65gto69's Avatar
I have not had these pieces refinished, just way too expensive.
Mark
Old 08-09-2021, 10:23 AM
1_Wild_Cat's Avatar
I spoke with the rep from Ogden Chrome this week at Hot August Nights - they are still doing pot metal plating/restoration. They have a good reputation in the west, but I haven't used them personally for pot metal.
Old 08-09-2021, 11:23 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Contact Tom Rubinate, he has a few nice tail panels.
Phone: 480 390 9058
Email: [email protected]
Old 08-09-2021, 02:03 PM
6t5gto 6t5gto is offline
I am having my rear panel and tail lamp bezels done at The Finishing Touch. $3,500 for all 3 parts. Absurd amount of money but you will pay at least $1,500 - $2,000 at a crappy chromer and get a crappy job. For the extra money at The Finishing Touch ( one of the best chrome shops in the country) you will get perfectly platted pieces and they also do the satin black on the rear panel and tail lamp bezels.
