Old 08-27-2020, 04:26 PM
Old Goat Racer's Avatar
Default CSR TRANNY SHIELD INSTALL
Thought I would share what I did with the tranny line fittings.
More than 1 way to do this for sure.
Hope the pics help
Ready for install ?
ID:	548033   Click image for larger version
ID:	548034   Click image for larger version
Everybody knows somthin.
Nobody knows everything !
The Following User Says Thank You to Old Goat Racer For This Useful Post:
Old 08-27-2020, 05:56 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I had to test fit mine and grind on the renforcing ribs on the tranny case.
Skip Fix
Old 08-27-2020, 08:47 PM
AG's Avatar
AG AG is offline
What dipstick are you using?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 08-28-2020, 11:31 AM
Yep. mine too. also cut the ears off each side so it doesn't hit the headers during install.
Old 08-28-2020, 11:38 AM
Bought it from Summit several years ago. Mite be a Lokar ?
I would have to dig through my old receipts.
Fits good, no leaks, fluid level a little hard to read
Old 08-28-2020, 11:41 AM
Installed it last nite. Those 3/8 bolts are a challenge !
Old 08-28-2020, 12:40 PM
AG's Avatar
AG AG is offline
Does it bolt into the case?
Old 08-28-2020, 12:51 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
Thats a Lokar piece. The quick release portion bolts to the case, comes with a plug too. Nice feature when doing and R&R.
Dave Polichena
Old 08-28-2020, 01:48 PM
Yes. need to drop the pan for install
NHRA approved
Old 08-28-2020, 03:48 PM
stags's Avatar
stags stags is offline
Used similar fittings on mine as well as the Lokar dipstick. Makes R&R easier. Also drilled holes through the floor to get at upper bolts. Not sure on A-bodies but pretty much a necessity on 1st gen F. Believe removing the ears and grinding case ribs are standard mods for a CSR on a 400.
Ain't as good as I once was, but I'm as good once as I ever was.
Old 09-01-2020, 10:04 AM
Rob B's Avatar
Rob B Rob B is offline
Wow, I see a solenoid there on the side of that case....going to the dark side I see?
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 09-01-2020, 07:02 PM
ponjohn's Avatar
ponjohn ponjohn is offline
I ran a Lokar tube a while back and it was painfully slow to fill. Did they change that?
Old 09-02-2020, 10:05 AM
Skip Fix's Avatar
The drilling holes in the floor for the top bolts sure sounds like a good idea. Those from underneath with a long extension and wiggler are hard and from the top even using one of those ratcheting boxed end take forever,
Skip Fix
Old 09-02-2020, 11:28 AM
NO !
Old 09-02-2020, 11:35 AM
Car had the t-brake when I bought it 10 years ago.
1st time I tried to use it I had a 1000 + RT. Took my foot off the brake pedal and kept holding the button staring at a green light. STOP LAUGHING !
I'm still damn good at footbraking though.
