OHC-6 TECH Over Head Cam projects, questions and advice.
Old 08-27-2020, 10:24 PM
Danf969 Danf969 is offline
Default Thermostat location?
I'm looking for confirmation on where the thermostat is installed.
I have a 1966 sprint 6, does the thermostat go first, then the by-pass spacer, then neck?
***OR***
By-pass spacer, thermostat, then the neck?
Thanks for your assistance!!
Old 08-28-2020, 06:27 AM
Jeff Hamlin's Avatar
Arrow 1966 WITH BYPASS
Old 08-28-2020, 09:33 AM
From the 66 tempest shop manual, the only image i can find shows flow direction from the by-pass to the pump. Now according to the image you sent and other similar images i have seen shows the thermostat installed first. So in that configuration and by looking at the shop manual this means that the pump is drawing fluid from the top of the radiator, correct?
This is why I am asking what seems to be a silly question.
Old 08-28-2020, 10:03 AM
694.1 694.1 is offline
The pump pulls cool water from the radiator & stuffs it into the block.
The Thermostat actually resides in the Cam cover.
Happy Cammin'!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 08-29-2020, 03:16 PM
I always have installed the thermostat in the bypass housing on a 66-68 OHC-6 engine, the purpose of the bypass housing is to have a small flow of coolant bypass the thermostat and keep some fluid moving at all times, Putting it before the bypass housing defeats the purpose I think. I have always thought the illistration was wrong in the manual.
But who knows I may have done it wrong for 40 years!
Old 08-29-2020, 05:20 PM
jmt455's Avatar
jmt455 jmt455 is offline
I thought the same thing.
What good does the bypass do if it's "after" the thermostat?
"Keep your stick on the ice...and your head up."
1910 Buick Model 19 Touring
1923 Cadillac 5 passenger coupe
1933 Pontiac 4 door sedan project
1933 Sport Coupe project
1968 GTO, 428, THM400, 2.73 posi cruiser
1969 Chevrolet C10 Fleetside, 350, THM400
1958 Buick Caballero 4dr hdtp wagon
2018 Ram 1500 to tow stuff
2024 Buick Encore GX
Exclamation Stop the press!
You know Jeff I should have caught that, but swung and missed
The recessed Thermostat seat in the Cam House is for non-use of a By-Pass, but PMD realized the need to get a small amount of Coolant to flow before full warm-up.
This is why they used the By-Pass.
The By-Pass also has a recessed seat for the thermostat which is re-located to allow a small amount of flow before the Thermostat reaches operating temp (OPENS).
So the sequence is Cam House, Gasket, By-Pass, Thermostat, Gasket, Outlet.
You would think I could recite this stuff by now
Old 08-30-2020, 11:31 AM
I've been beating my head against the wall on this stupid little issue... on one hand I have the manual saying one thing, illustrations showing another.
THANK YOU for showing the correct way, and confirming what I thought to be correct.
Time to tear down and reinstall.
Also, thank you for posting on the Cammers Facebook page!
Old 08-30-2020, 01:42 PM
Hey, what's a couple of gaskets among friends
Thank the other Jeff for pointing out the flub.
Cheers.
