Anyone ever see this???
Getting ready to assemble the short block and noticed this oil restrictor. This pic is the upper saddle of #1 main bearing and the restrictor is threaded into the oil passage that goes to the pass side lifter galley. Thanks KC
I have never seen that but after extensive study of the Pontiac oiling circuit, it makes sense.
I am not understanding that as according to my oil flow schematic I made a number of years ago the number 1 main hole in the block only feeds the number 2 rod Bearing and the number 1 Cam journal, am I wrong ?
If I am wrong then how are the driver's side lifters going to be restricted restricted other then in each lifter Bore?
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 09-18-2020 at 12:08 PM. |
It will keep more oil to the bottom and less oil to the lifters on one side of the engine... High RPM road race conditions leave it in, street type deal or drag race I would remove it... JMO
| The Following User Says Thank You to PAUL K For This Useful Post: | ||
Jeff Suchma here in Houston had a RAV block that had restrictors in all the cam bearing feed lines when he got it. I don't remember the history on that block.
Jeff at one time had a clone of the Gay Pontiac funny car but I never heard he completed it.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune [email protected] 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
A local guy here restricted all five cam bearings using a hole in the restrictor larger than the hole in the cam bearings.
How does that make sense?
I want to think I saw an article on a Mondello Olds build and their passages were similar and he used a restrictor there.
Did not realise the factory (or other builders) did this.
We did the same on our 408 jetsprint engine for sustained WOT 6.5k rpm usage. Restricted at this crossover galley, and redrilled / clocked cam bearings. All our oil pressure was logged at the No1 main via a tube out the front of the block, not at the rear.
Working on going faster (and now staying dry at the same time !!) |
This block was supposedly owned by Buck Baker when he ran a 69 Firebird in Trans Am Racing which would explain the restrictor.
Paul K , I was thinking the same thing, remove it for street driving. Thanks for the replies. KC
| The Following User Says Thank You to Aluminum Chief For This Useful Post: | ||
It doesn't that's what makes it funny!
Good luck with the project!
