plastic front valance
will i be able to use a plastic front valance on my 72 existing front bumper nose
Do u have an original or aftermarket...???
It should fit from what I know I think 72-73 left factories with the plastic valance but were damaged easily and changed out to the steel ones... I prefer the look of the plastic one...Chris
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 09-19-2020 at 10:00 PM. |
no i am missing the valance
I’ve also heard they require a lot of work or “ could “ require ....to fit correctly ....That was one reason why I decided to stick with the steel...
I see early birds offers a fibreglass unit...wonder how they fit....Chris https://www.early-birds.ca/part_827_...98-125024.html
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's Last edited by cnc; 09-19-2020 at 10:10 PM. |
anyone else have any input on this
Bought a original and had to fix it.
Mike/Illinois |
The Following User Says Thank You to Judge273 For This Useful Post: | ||
Those noses look so much cleaner with the plastic panel. Car looks great!
looks great , did it bolt right up on the bumper or did you have do get different parts to install it
I love the look of the plastic valances too, but nowhere as durable as the tin part. |
do u have a photo of that bracket |
As long as you don't hit anything, the plastic holds up well.
I think it's this one?
(bolts to bottom of the upright for the hood release)
do u mean bracket number 6
Bracket 6 is available from Ames
I have an original if interest?
Any one else seen another of this oddball? |
I have an original bracket not the actual Valance. Just wanted to make that clear. I did reply to the pm this morning. Cheers
That first bracket looks more like an exhaust manifold locking washer with bend over tabs that someone has made 'work'.
