Old 10-07-2020, 08:31 PM
footjoy's Avatar
footjoy footjoy is offline
Default Drive Shaft Tolerance
Can some one tell me what is an acceptable runout on a drive shaft.
Greg
Old 10-07-2020, 10:44 PM
428goat 428goat is offline
i would say none. if you have a problem take the shaft to a driveshaft to a driveshaft shop and they will check it for being bent and /or out of balance.
Old 10-07-2020, 10:46 PM
694.1 694.1 is offline
I had less that .002 wear in the rear bushing of my automatic trans and a new bushing smoothed things out. That was an eye opener!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 10-07-2020, 11:21 PM
To make it clearer, if it is not straight and balanced you will have a problem
Old 10-08-2020, 05:24 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Max runout on a steel driveshaft is around .010” at the center of the shaft for factory tolerance. Most good shops get it down to .005 or less.
You would have to be some kind of ninja to get a 50” long welded shaft to .000” across its entire length.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
Old 10-08-2020, 08:00 AM
footjoy's Avatar
Thanks for the replys mine had .050. So he is making a new one. He said .015 is the most out of a used shaft.
Greg
Old 10-08-2020, 08:38 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
Ive seen bent / undersized driveshafts break auto trans cases starting where the bellhousing narrows down near the pump.
Clutch Guys Matter
_______________________________________
53 Studebaker, 400 pontiac
72 4-4-2 Mondello's VO Twister II
1964 F-85 Home of the 700hp small-block Olds
**Still wanting a 64 Bonneville or Catalina**
Old 10-08-2020, 08:44 PM
Schurkey Schurkey is offline
My Trailblazer had a horrible shake at ~74 mph. Rear U-joint was toast. I took the shaft to the local fabricator, they put in two U-joints and put the shaft on the lathe. They said it was .050 TIR, and they straightened it to about .020. Trailblazer was startlingly smooth afterwards. Lasted about two years.
The warp must have come back, 'cause I had the same shake at the same speed, only this time the front and rear U-joints were still good. I slapped a Treasure Yard driveshaft on it after replacing only the rear joint, and it's back to being nicely smooth again.
