Old 10-16-2020, 04:38 AM
taf44667 taf44667 is offline
Default What is the correct Drum/Hub Style Assembly for a 69 GTO
Need some help figuring out what is the correct drum/hub assembly for my 69 Judge project. Manual drum brakes.
I believe that all drum/hub assembly's were swaged together in 69 as the 2 I have are currently, the 3rd example is not.
Were they different for Bendix/Delco?
The one in the first 2 pictures I believe is the correct style. Its a BUDD and has the correct date code for the car. Also has a smooth round exterior hub.
The one in pics 3 and 4 has a different fin pattern and the hub is notched not smooth.
The 5th example drum has additional holes and was not swaged?
Can anyone identify what is the correct Drum/Hub assembly for a late build 69 Judge built in Michigan?
Any help is appreciated.
ID:	551522   Click image for larger version
ID:	551523   Click image for larger version
ID:	551524   Click image for larger version
ID:	551525   Click image for larger version
Old 10-16-2020, 12:39 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
The only part number I have for 69 regular production manual front drums is 9798690 superseded by 481832.
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
Old 10-16-2020, 11:13 PM
Thanks, after some additional research looks like pics 3 and 4 are correct manual drum.
Old 10-17-2020, 10:38 AM
hawkins69 hawkins69 is offline
My 69 nov 68 built in Fremont, has both styles on car. Was all original and I bought from Original owner back in 2004. Still on car now. If your in need of drums, a have several originals I would sell cheap
Old 10-17-2020, 11:53 AM
That’s interesting. Are there other examples of original cars having different appearing drums. They function the same but just appear different. This was a Michigan built car with only 56,000 miles and everything else seems to be original to the car.
I’ll get back to you on drums once I figure out what I need.
