Old 10-16-2020, 10:36 PM
A390GT's Avatar
A390GT A390GT is offline
Default 15 Ralley ii with a smaller 14 center?
I picked up a set of 5x5 15inch ralleys and didn’t realize they had a smaller 14 inch center section.
I measured and they are a 15 inch rim with a 5x5 bolt pattern
Did these come with or without a trim ring?
The date code indicates it was made sept. 13 1968 JJ
ID:	551581   Click image for larger version
Old 10-17-2020, 09:49 AM
694.1 694.1 is offline
I think in '67, 14 inch R IIs were a 1 year only for the Full size cars. Makes sense that in '68, they may have not graduated to a "real" 15 inch wheel but upgraded the 14 inch center.
Cool, regardless.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 10-17-2020, 12:53 PM
A390GT's Avatar
I grabbed the 15 inch trim rings off the 15x7 I have on the Catalina 2dr.
They do fit, the 15x6 with the small center they just show all of the smaller center. (Lower 2) unlike the bigger center 15
I’ll paint these up and run these until I can find 2 more of either style.
Anyone know the tire size they run on these? I’m going to put these on the wagon.
Old 10-18-2020, 10:51 AM
muscle_collector's Avatar
i ran the JY code 15 with the 14 center (often mistaken for the JW)on my trailer for years and ran 235 75 15
Old 10-27-2020, 09:57 AM
I'm not sure I understand this. Are you saying that the earliest 15" 5x5 rally wheels used a smaller "flange mating area" than later ones?
From the pictures I see that the lower ones look like the lug holes are out at the edge of the mating surface, while the upper ones look like the holes are centered.
I'll look at mine tonight, curious now.
Old 10-28-2020, 06:24 AM
A390GT's Avatar
North,
the center section is smaller on the early 15’s it measures like 12 1nches compared to 13 or so for the later 15’s
You can see the difference inside the trim ring. You can see the gap in the inner and outer rim seam with the early rim
Old 10-28-2020, 10:02 AM
A390GT's Avatar
I’d like to find another pair of the small center 15/6 because I think they will look good running with no trim rings.
Im picking up the 15x6 big center from the tire guy today. I just painted them and put 235-70/15 on them.
Old 10-29-2020, 10:04 PM
A390GT's Avatar
Mounted 235/70 15’s
Old 05-20-2021, 09:33 PM
Petegto Petegto is offline
I believe I have 2 of them I’ll check my garage tomorrow and let you know.
Peter
Old 05-20-2021, 10:09 PM
Have owned several dozen small center 15x6 Pontiac Rally II's (there is more than one application code).
Also like Gary ran quite a few on one of my open car trailers.
One thing to double check is the lug nut holes.
A TON of the 15x6 Pontiac Rally II's have stretched lug nut holes thanks to tire shop idiots with impact tools. One will even run across stretched lug nut holes on 15x6 Rally II equipped boneyard big cars that haven't been to a tire shop in 40 years!
Old 05-21-2021, 06:23 AM
A390GT's Avatar
I went to spring Carlisle and walked around forever and found another small 15x6 and a large 15x6 for 50 bucks...
So now I have 3 of each.....
The other thing besides the lug holes is rust penetrating the weld seem on the backside.
I had one rim that looked good but was scary after it was dipped.
I’m Looking for another set of 15x7 for the wagon because they apparently look good on my dads car...
I might steal back the front 2 and do 6’s on the front and 7’s on the back of 2 cars
Pm me if you find them
Old 05-21-2021, 10:32 AM
I have a set of 15x7’s if interested
Old 05-21-2021, 12:59 PM
A390GT's Avatar
Peter, Pm me with pics and prices.
How far upstate are you?
Old 05-21-2021, 03:39 PM
Ok I’m in Utica NY about 50 miles from Syracuse east
I’ll take a few pictures toy and send them
Old 05-24-2021, 11:54 AM
15” rims 7” wide I have only 2 left.
ID:	567162   Click image for larger version
ID:	567163   Click image for larger version
ID:	567164   Click image for larger version
Old 05-29-2021, 09:16 AM
mjs5678 mjs5678 is offline
Here's my 15" wheels on the 69 Catalina. I don't know how long these wheels were used.
Name:	2020-12-27 18.35.32.jpg
Old 05-29-2021, 12:03 PM
A390GT's Avatar
Mjs, nice.
Are your center sections smaller? I can see the grey around the edges.
I have the rounded trim rings on mine and it covers that section up.
I wonder if there are different style trim rings for big cars, or maybe that’s an A body 15 inch trim ring?
Old 05-29-2021, 12:34 PM
Yes they are the small center, I believe they are the wheels and trim rings original to the car.
Old 12-21-2021, 02:16 PM
IIChileII's Avatar
IIChileII IIChileII is offline
interested !! please PM me with info
Old 12-21-2021, 02:19 PM
IIChileII's Avatar
hey guys, just wanted to throw it out there, i have a 1968 GP that im looking for 14" or 15" rally II for. if anyone is holding and willing sell/ship, please PM me
