Old 10-17-2020, 02:14 AM
Tommo99 Tommo99 is offline
Default 67 Lemans body onto 65 GTO chassis
Hi there can someone tell me if the chassis are the same 65-67, I have a 67 Lemans that I'm about to restore and have just found a 65 GTO rolling chassis with reconditioned engine trans diff etc I think the 66-67 bodies are slightly wider and longer but can't find any info on the chassis to see if they are the same any help would be appreciated cheers
Old 10-17-2020, 10:35 PM
GT182's Avatar
GT182 GT182 is offline
Long ago I was told I could have used my 1st 66 GTO's frame for the body of a 65 Lemans. Both were 4 speed cars. My GTO body was totaled, the Leman's frame was totaled. I was told that but didn't get to do it as I was told after I'd sent what was left on my GTO to the junk yard.
The serial numbers are on the left rear top of the frame behind the quarter panel wheel well if you want to keep serial numbers. And don't forget to check the body mounts and change them if needed.
Good luck Tom.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 10-18-2020, 03:24 AM
Geoff Geoff is offline
In the resto book, 64-67 frames are lumped together & have the same dimensions & data points. Part #s were changed, but Pontiac seemed to do that when nothing had changed with the part. Maybe they had excess paper they had to get rid of....
So I think you are safe.
Old 10-18-2020, 09:09 AM
Big Bear's Avatar
Big Bear Big Bear is offline
The 67 rear spring reduces size at top . 64-66 has a large top spring pocket.
Old 10-23-2020, 06:30 PM
geeteeohguy's Avatar
This^^^. The '66-'67 rear axle is an inch wider than the '65, but the frames are otherwise dimensionally the same. Since your car is a LeMans, it came with a manual trans or the 2 speed auto, so the trans crossmember mounts should be in the same location as the '65 frame. Go for it. It's a straight bolt-up-and-go deal.
Jeff
